Wheel bearings making noise
Old Jul 20, 2005 | 12:50 AM
Flatty's Avatar
I just installed a new set of wheel bearings ion my Cummins, and they are making a weird scraping sound when I drive. It is almost a high pitched griunding sound coming from the front end. What can this problem be?
I torqued the bearings down to 140lbs. Is this too high, or just the right amount? The steering is a bit tough as well, and the truck is wandering a bit.
Please help me
Dimitri
Old Jul 20, 2005 | 12:06 PM
kandgo's Avatar
The correct torque is 180ftlbs on the hub bearings, 122 ftlbs on the hub bearing bolts. I would jack her back up and look to make sure it went back together. Like the hub spacer is on correct with the flat side to the rear etc. etc. Goodluck,,Rick
Old Jul 20, 2005 | 04:25 PM
Flatty's Avatar
What hub spacer? I have the hub put on in the following order...
Dickl backing palte, Hub spacer, hub, rotor.
Dima
Old Jul 20, 2005 | 05:40 PM
kandgo's Avatar
Old Jul 20, 2005 | 07:09 PM
Flatty's Avatar
Yup, had the assembly on bacwards. I tore the whole thing apart, and put it together right. Now the noise is gone. I also found that the rubber bushings for the caliper (where the 2 bolts go in that hold the caliper to the mount) were missing. I found the clunking sound... All in all a good day.
DIma
Old Jul 20, 2005 | 09:12 PM
kandgo's Avatar
Great. We are all prone to getting somethings backwards sometimes!! Goodluck,,Rick
Mutt68
Sep 25, 2012 12:51 PM
ctd4stan
Jan 23, 2011 11:44 PM
Wilbur01
Aug 3, 2009 11:16 PM
jetsnow
Sep 10, 2006 12:09 PM
lovemysan
Sep 30, 2005 08:33 AM
