What is this PLUG for? 93 CTD
Old Feb 13, 2006 | 03:31 PM
manganos's Avatar
What is this plug for? I'm was going to install my brake controller and saw it? It is located to the right of the "HOOD" latch inside the truck. Thanks!! (Thanks Shovel for the quick approval)
Old Feb 13, 2006 | 04:12 PM
manganos's Avatar
And where do you connect the red wire from the brake controller. The instructions suck!!!
Old Feb 13, 2006 | 05:36 PM
wreckere022002's Avatar
might be
well if i am reading this book right it is the rear wheel anti-lock control module dont hold me to it dont know where the red wire goes
Old Feb 13, 2006 | 05:39 PM
manganos's Avatar
Wow, Thanks! I still don't know why it would have a plug right there unless it had something to do with wiring up the brakes. Maybe its for anti-lock TRAILER brakes
Old Feb 13, 2006 | 05:50 PM
spunbearing's Avatar
My 93 has the RWAL module behind the glove box. No idea what that plug is. Mine doesn't have it. Heres a pic of where the red wire goes to on my brake controller. It's the white wire without the stripe.[IMG][/IMG]
Old Feb 13, 2006 | 05:52 PM
Heres another pic farther out. Don't mind my dirty truck and cigar ashes.[IMG][/IMG]
Old Feb 13, 2006 | 06:01 PM
Lil Dog's Avatar
The two pin plug is for the RWAL. There is a connection process to connect to that lead to test the RWAL module.
The red wire to your controller would go to the output wire from the brake lite switch up by the pedal. I can't remember which one I used, but a testlight made the decision pretty straight forward.
Old Feb 13, 2006 | 06:18 PM
manganos's Avatar
Thank you both. Now I can go tear into the wiring harness. Thanks again.
Old Feb 13, 2006 | 11:41 PM
Arrow asked the last owned cuz was not sure
well its in mine and from what i was told from thhe last owner ther was an adapter that hooks up to it for the jake brake witch brand dont know hes looking at what he pulled out for me tonight
Old Feb 14, 2006 | 12:17 PM
apwatson50's Avatar
I am pretty sure that thats the plug for a tach. Should be a 4 pin plug? The 91.5-93's were pre wired for a tach and thats the plug for it.
Old Feb 14, 2006 | 12:34 PM
Lil Dog's Avatar
That is not the Tach harness. That is the RWAL harness. The Tach hookup is up under the dash closer to the dash cluster on the loom from the steering column and it is a 4 pin connector, Ground, Power, Illumination and Tach signal..
As far as the "Jake Brake" hook up, I would say no.. That system would be a totally separate add on. There was NO pre-wiring for an exhaust brake. You might have pre-wiring for a brake controller if the trailer package was installed at the factory.
royta
Nov 25, 2016 11:48 AM
jeeper50
Sep 29, 2011 06:04 PM
smokinram99
Jul 28, 2009 10:07 PM
ctturbodiesel
Dec 13, 2006 09:37 AM
