VP44 sick, where to buy????
VP44 sick, need HELP ,where to buy replacement????
I have had a few momentary "dead pedals" a day traveling 200-300miles & towing for a while now. I made it to our winter location in AZ. The last 4 days I have limp mode in the morning (not towing) and need to go 1/2 to 1 mile before it kicks in. Then have occasional "dead pedal" after that! My "limp mode" has NO SMOKE and in neutral will rev up, just no power!
I have codes, pcm 1693, & ecm 0216 that when cleared, will come back.
I have had, 12-14 psi at Vp44 at all times (relocated lift pump to rail 2 yrs ago)
I have calibrated & reset APPS and confirmed good voltage at PCM when limp/DP occurs.
I have removed and inspected PCM for good conn and no cold solder joints
I have confirmed map sensor volts are 1 volt and increases with RPM's, goes to ~1.5 volts in Limp mode under acceleration then ~2.5 when Limp ends???
I have not had the pcm/ecm software re-flashed but at this point I am ready to order a rebuilt VP44. MIDWEST FUEL INJECTION seams to have the best prices and terms. Anyone used them??? Any other companies you would recommend before I spent the $$grand++?????? see my sig for truck info, now 92k miles.
PM'd you
I PM'd you but maybe screwed it up because it's not showing up in 'sent items'. I ran across this yesterday on the Las Vegas Craig's list. I don't know the seller, but this is listed at a price that's only $200.00 over what most places get as a core charge.
http://lasvegas.craigslist.org/pts/1462536528.html
Pa outlaw
Jun 23, 2004 09:30 AM
FiverBob
13
Oct 14, 2003 12:57 AM
