valve cover bolt broke off plz help
Old Jan 25, 2007 | 06:33 PM
blueboy16's Avatar
ok one of my valve cover bolty got broke off when i was trying to tighten it cuz it was leaking. i need to kno if i could fix it myself or to take it in to the shop?
Old Jan 25, 2007 | 06:44 PM
Rocky5.9's Avatar
You need to go get your self an "Easy Button". I'm only kidding...How deep is it broken off?
Old Jan 25, 2007 | 06:46 PM
blueboy16's Avatar
not very deep about 1/4 inch or less
Old Jan 25, 2007 | 06:55 PM
Rocky5.9's Avatar
To be honest I have never broken one off on one of these engines. I have broken them off on big block Dodges before. I had plenty of access to strain and plenty of room to throw vice grips when I broke easy outs and room to yell obscenities when I broke the skin on my knuckles. Have you considered using an easy out?
Old Jan 25, 2007 | 06:57 PM
blueboy16's Avatar
no i havent i just thought i get on here and see if i could get another opinion first ill have to go get one and try it. thank you for your time ill let you kno what happens or when i get it fixed.
Old Jan 25, 2007 | 06:59 PM
Rocky5.9's Avatar
Just becareful not to damage the threads on your head......
Old Jan 25, 2007 | 08:08 PM
D2 Cat's Avatar
I haven't removed one from a Cummins, but I've removed alot of broken bolts. One method is to get a good center punch and get a dimple started in the center of the broken fastener. Then get a good set of left-hand drills, and select the correct size (be sure to clear the threads) and drill it out. (Be sure your drill is in the REVERSE position.) Often the heat of drilling and the counter-clockwise rotation will just turn the broken piece out.
Old Jan 25, 2007 | 09:32 PM
blueboy16's Avatar
ok thank you all for your help!
Old Jan 25, 2007 | 09:38 PM
SRTchris's Avatar
Thumbs up
good tip there guy!!!!
Old Jan 27, 2007 | 02:01 AM
blueboy16's Avatar
Talking
well i got it fixed got an easy out and it came right out thank you all for your help
Old Jan 27, 2007 | 09:50 PM
D2 Cat's Avatar
If you ever break a bolt off and it's protruding out even a little bit you put a nut OVER the broken bolt and weld the nut to the bolt. You can do it with a stick welder but a wire machine makes it much easier. As soon as you're done welding pour cold water over the nut/broken bolt, then wrench it out.
You can even get special rods for this type of application. An 11080 rod works pretty good. It has more tensile strength then the common 7018.
Old Jan 31, 2007 | 11:44 PM
blueboy16's Avatar
ok thanks for the tip
hounddogks76
Feb 19, 2011 09:15 PM
4969joes
Mar 27, 2010 08:58 AM
Oldschooldodge
Jan 2, 2008 03:42 PM
displacedtexan
17
Dec 7, 2006 09:13 PM
Stevenc
Sep 27, 2004 06:32 PM
