Turn A\C ON and Kills Engine 97 12v auto
Old Jun 28, 2006 | 09:44 PM
Big Ben's Avatar
My 1997 12v Automatic will choke down labor and die when the A/C is on after it has ben running for a couple of minnutes. It only happens when it is in gear, Drive or Reverse with your foot on the brake pedal. It is like the (fast Idle solonoid on a gas burner) engine is starving for fuel. If you give her just a slight amount of gas she is Ok however no gas and it will stall and quit running. I have checked my high and low pressures on the A\C system and they are normal. The problem has slowly gotten worse. In the past it would only stall in reverse while backing my boat down the launch ramp while applying the brakes. I could remedy this by throwing her in Neutral or just turning off the A\C now she has slowly gotton worse where she stalls in drive with the A|C on and Brake applied. Does it have a high idle solonoid or something that advances the throttle when the ac is on? Is the power stering pump working extra hard to supply the power brakes? I am not sure where to start searching for my problem? Thanks in advance for your Help.
Old Jun 28, 2006 | 10:21 PM
fschiola's Avatar
Have you checked and set your idle speed lately? They do need periodic adjustment. Check here for the instructions.
Click
Remember that the idle speed is checked with the the transmission in drive and the A/C on.
Old Jun 28, 2006 | 11:21 PM
RCW's Avatar
RCW
You need to have the engine retimed. The idle speed slowly drops over the years as the timing starts slipping back. Get it set back to where it should be and your idle will pick right up, you will also regain the power you have lost over the years.
Old Jun 28, 2006 | 11:41 PM
J BODY's Avatar
While having the timing checked isn't a bad idea on an older high mile 12V, fshiola's information will give you the results you are looking for.
rotohead
Jan 9, 2013 04:44 PM
wyattearp29
Apr 25, 2009 10:04 AM
Rockcrawler
16
Apr 20, 2009 07:59 PM
stealman1
Nov 9, 2007 11:07 AM
Jessm
Sep 13, 2004 01:18 PM
