turbo maybe shot
Old Dec 28, 2004 | 08:47 AM
racermatt2606's Avatar
turbo maybe shot
the otherday when i turned off my truck i thght i heard something in the turbo area. something liek metal rubbing. maybe i was just imagining it. but then i went back out later when it was cold and pulled off the turbo intake hose and checked to see if it was losse or wobbled or anythign and it felt free and everything. so then i had my gf start the truck and then i revved it up and gave her the signal to shut it off. and it stopped abuot 8 seconds after shutting off. normally it spinns for abuot 45 seconds or more. but then i got to thinking that could been becuase it was cold and everything right there. then when i go to leave that night the turbo was sounding liek a ford turbo. it sounded liek it was alot louder and whistled alot more. maybe its just my sinuses playing with me or something. i sure hate head colds. oh yea and i did put back on the intake hose so that was not it. im pretty sure it is fine becuase ive shut it off alto more and aint heard that noise again. so maybe im ok. what do yall think?
Old Dec 28, 2004 | 09:22 AM
infidel's Avatar
My bet is it's ok
Old Dec 28, 2004 | 04:49 PM
MnTom's Avatar
Next time pull the intake hose off and look for any marks where the blades have been rubbing. Try to make it rub. If you see any marks or can make it rub, your turbo needs attention. I kinda doubt that you will have any rubbing issues. Have your boost levels changed? If so, look for a boot leaking or even the intake gasket(s) leaking. Let us know what you find out.
Tom
Old Dec 29, 2004 | 03:07 PM
spunbearing's Avatar
Matt, mine does that sometimes too. I can hear a sound like a bearing rubbing when the turbo winds down with the engine off. Sounds like the sound is coming from the glovebox. I had my diesel mechanic check it out and he told me that turbos hardly ever go out. I think I'll change it anyways just because. I'd rather buy a new turbo than a new turbo and intercooler and whatever else the scattered parts may break.<edit> one more note. The turbo is fed pressurized oil from the enigine. When the engine is turned off there is no longer any pressurized oil being fed to the bearings. With the open element air filter maybe the noise is just more noticable.??????
Old Dec 29, 2004 | 09:48 PM
Kyle Graham's Avatar
I have always heard that scraping spinning sound when truck is turned off you can really hear it with open air intake maybe that is all you are hearing
Old Dec 29, 2004 | 09:59 PM
thanks yall. but i guess its ok now. it must have just been my imagination. thanks again
farmboy99
Aug 27, 2012 08:03 PM
thomasb
Dec 20, 2009 10:24 AM
Igor
Jun 17, 2008 03:20 PM
Syndicate
Feb 21, 2006 06:34 PM
cLAYH
Jul 16, 2004 03:31 PM
