Turbo Boost Gage
Old Jun 4, 2005 | 08:16 PM
DODGE 92's Avatar
Question Turbo Boost Gage
i got a question i wanted to put a mechanical turbo boost gage in my truck i now were to put it my question is a friend gave me a brand new manifold pressure gage goes from 0 to 30 on gage it says INS/HG i want to now is this same thing as turbo boost and ins/hg wat kind of mesurment is that i think turbo boost is in psi wat is diference im just wondering since ITS FREE maybe i could use it
feedback will be apreciated thanks
Old Jun 4, 2005 | 08:21 PM
rockwithjason's Avatar
It's probably a combo boost vacuum gauge. The gassers use them. I belive it's measuring inches of mercury. Boost gauges are so cheap why bother with second rate stuff? Check ebay for autometer z series boost gauges and see what you can find. I got my pyro for $50 less than anywhere else that way.
Old Jun 4, 2005 | 08:34 PM
That's a vacuum gauge. Not gonna have any of that on your Cummins. You could install it as a filter minder though, just plumb it in between the filter and the turbo.
Old Jun 4, 2005 | 08:47 PM
infidel's Avatar
Dave, that has been my opinion also for a vacuum gauge use also but I've never tried it and several people have told me it won't work.
For reasons I don't understand folks say that the gauge has to be somehow designed around the particular filter you are using. This is apparently why the filter minder only works correctly on the factory airbox and nowhere else.
I can't understand it since the filter minder is nothing more than a simple vacuum gauge.
Old Jun 4, 2005 | 08:54 PM
I can't imagine why it wouldnt. Vacuum is vacuum, it always sucks.
I've seen a few filter minders that plain don't work no matter what you do.
The only way to know for sure is to hook it up and try it. Next time I'm in the backlot at one of the truck shops I go to I'll try to liberate one off a wreck. I'd be interested to know if my gray BHAF is a restriction yet.
Old Jun 4, 2005 | 09:08 PM
infidel's Avatar
Let me know how it works.
One of the people who told me it wouldn't should be an expert, Scotty.
Old Jun 5, 2005 | 08:14 AM
RAM2940's Avatar
I wonder if you could use it to monitor your vaccuum pump?
Old Jun 5, 2005 | 08:22 AM
Sure, but I think that would get boring. The red brake idioit light will turn on if the vacuum gets too low.
bocuso
Jul 22, 2005 08:45 AM
dieselhawg
Feb 18, 2005 09:38 PM
BC847
Feb 12, 2005 11:31 AM
Haulin_in_Dixie
Apr 16, 2004 02:44 AM
Jim in Co
Apr 28, 2003 06:01 PM
