Truck won't start in cold
Old Feb 12, 2006 | 05:07 PM
txcoastie81's Avatar
Hello, Ok I am new to the cold weather and my truck will not stay running. I am in the northeast right now and we just got alot of snow. I drove it this morning twice with no problems but now it will start for a few seconds than hesitate and die. I tried starting it for 10 minutes and nothing. My truck has been plugged in all night and all day. It sounds like fuel starvation so I am wondering if I have some gelling going on but I have no idea. I'm from Texas and never have had to deal with this. Any help would be appreciated. Thanks
Old Feb 12, 2006 | 05:19 PM
sherod's Avatar
If you are running Texas fuel, you might be gelled. Straight #2 starts getting nasty around 20 degrees from my experience.
There is a product called 911 that can help. Never had to use it, but someone will jump in soon with their ideas.
Can you point a torpedo heater under the truck for a while?
By the way, welcome. I see this is post 2 for you.
Are you out of Corpus? My boy was there for about 2 years doing port security.
Ed
Old Feb 12, 2006 | 05:20 PM
BPDODGE's Avatar
Sounds like gelling to me. Power service additive is the best solution I know for that. They sell a product called diesel 911 that is good for getting a gelled truck up and going again.
Old Feb 12, 2006 | 05:30 PM
Thats what I figured but just wasn't sure. I am running local Rhode Island fuel. I thought it would be ok considering there should be some kinda anti-gel additives in it. I will try and locate some of the 911 and see what happens. I really dont have a way to put a heater under the truck. I am from Houston and was lucky enough to get stationed back there for a little while but now I am up here. Thanks Sherod and BPDODGE. Nice to meet ya'll
Old Feb 12, 2006 | 06:03 PM
infidel's Avatar
Rhode Island fuel shouldn't be gelling.
I didn't think the temps in the NE today were much lower than 25F
Old Feb 12, 2006 | 07:52 PM
I just went outside and popped open my fuel filter. i turned the ignition on a couple of times to let the pump cycle and I got nothing but i here it running. I filled up the canister with good fuel and after about 2 minutes of priming it up it started for about 30 seconds and then died again. So I am back to square one. I'm going to wait till tommorow and tackle it again. I think my next option is the diesel 911 or get it towed into my shop at work so that I can thaw the thing out and try it again.
Old Feb 14, 2006 | 08:53 PM
Rganser's Avatar
are you pushing the go pedal? Mine wont run unless I touch the pedal due to the idle being too low.
Old Feb 15, 2006 | 01:14 PM
Ok so I got my truck into the shop and did some troubleshooting. I took out the fuel filter and ran the transfer pump and I had nothing coming out so I seperated the supply line under the drivers side cab and put a vacuum pump on it and I got nothing. I blew a little air into the line and tried it again and I got fuel. I hooked it all up and sure as hell it ran fine. I dropped the tank to see whats going on and I found a crap load of sludge choking up the pickup tube. Oh well I'm glad it's fixed. Thanks to everyone who posted.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Big Mac
Apr 4, 2008 03:17 PM
Luvnacumns
22
Mar 22, 2007 09:15 PM
