Truck won't start
Old Oct 13, 2005 | 07:45 PM
Silverjay's Avatar
Truck won't start
Truck ran great at lunch. When I tried to start after work....nothing. No click, just won't start. I found the 20A starter solenoid fuse under the hood blown. I replaced it once and it blew again. I think the solenoid is bad. Do I have to replace the entire starter assembly ($200) or can you just replace the solenoid? Does this sound like the problem?
Old Oct 13, 2005 | 08:11 PM
ds1rider's Avatar
Hopefully just the solenoid. My fuse went out a month ago and it took me all day to find it. Who has a starter fuse??
Old Oct 13, 2005 | 08:38 PM
RCW's Avatar
RCW
Do not spend a dime on any fix, until you do the one outlined here. Everything else is a waste of money. http://www.fostertruck.com/contacts_install.htm
Old Oct 13, 2005 | 08:50 PM
Geico266's Avatar
I agree. Take a look at my pics to see what old contacts look like. You can rebuild most of the parts that wear in these starters pretty cheap.
Old Oct 14, 2005 | 01:49 PM
Silverjay's Avatar
Starter solenoid contacts were bad. A local "shop" changed the contacts for $35. Good as new.
Old Dec 12, 2005 | 02:26 PM
1st dodge's Avatar
wow, sounds like you are driving my truck. three weeks ago my 99 lost the injector pump and lift pump ($2,100). Drove it for two weeks then yesterday it started just fine. drove it to get fuel and it would not start, click or anything. I let it roll back and popped the clutch and it started. However, the speedo does not work, abs light and airbag lights are on, power windows do not work and fan on the heater dopes not work. Are all of those related to the same fuse?
Old Dec 12, 2005 | 03:31 PM
Silverjay's Avatar
I don't think so. All of the auxillary things you mentioned worked on my truck when the starter fuse was blown.
Old Dec 13, 2005 | 03:08 PM
1st dodge's Avatar
Is there a starter relay AND a starter fuse?
Old Dec 13, 2005 | 03:19 PM
Silverjay's Avatar
Yes, I think the relay is in the fuse box under the hood next to the fuse.
Old Dec 13, 2005 | 03:23 PM
1st dodge's Avatar
I found the relay but are you saying that there is a fuse as well? If so, where is it located?
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
