truck won't start
Old Feb 6, 2005 | 08:46 PM
bkcalhoun's Avatar
truck won't start
Been having trouble starting my truck in the cold (below 20f) all winter if its not plugged in. Changed fuel filter 3 days ago. It has also been cranking longer for all starts(4 or 5 turns instead of usual 3). Would not start at all this a.m. I don't have a fp gauge but I get fuel out of the test port on the ip, and I can hear the lp running. no codes stored. any help???
Old Feb 6, 2005 | 08:56 PM
phox_mulder's Avatar
Welcome to the board.
1st off, what year vehicle might you be inquiring about?
phox
Old Feb 6, 2005 | 08:59 PM
bkcalhoun's Avatar
I will modify my signature it is a '00 2500
Old Feb 6, 2005 | 10:56 PM
Hemi Cat's Avatar
First thing I would check is the intake air heaters. There are 2 heaters and 2 solinoids thet get power from the drivers side batt. Sometimes the wires that go to the batt get corroded and the heater stops working. The next thing to check is for air leaks in the fuel supply lines. Your truck is getting old enough to start having those problems. If a hose looks questionable, just replace it, it's cheap. The next thing to check is the condition of the batts. If they are original they may be getting weak and not cranking the motor fast enough. Do a volt check while cranking. Should be 10.5 or above while cranking, and a fast recovery to 12.3 within 10 sec. If it falls short, replace the batts.
Old Feb 7, 2005 | 06:13 AM
bkcalhoun's Avatar
Good morning- thanks for the reply!!! The batts were my first thought. I replaced them last month. The grid heaters appear to be working. I didn't volt them but the lights dim and brighten OK. It was 55f here yesterday and it won't start at all. I am on my way out to the driveway to get started, I will let you know what I find. Thanks again
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
