Truck won't start!
07.5 6.7 won't start. The truck started running bad the died, now it won't restart. I have about 10 psi from the lift pump, and according to my scan tool I have between 10,000 and 12,000 kpa of fuel pressure at the rail. I pulled the fuel line off on the back of the head and I have no fuel coming out of it. I was told if the injectors were bad that alot of fuel would be coming out of that line when I tried to start the truck. I have the exhaust pulled off to eliminate the possibility of a clogged exhaust keeping it from starting. The map sensor reading while cranking is 100 and the mass air flow is reading between 7 and 10 g/sec. Anyone have any ideas?
Subliminal
Dec 15, 2010 04:35 PM
Machinos
Mar 16, 2008 01:34 AM
