Truck started then died after 2 minutes
Old Jan 24, 2011 | 07:56 AM
st.rodder2's Avatar
Angry Truck started then died after 2 minutes
Started my truck this morning to let it warm up and It ran for about 2 minutes then it started to run rough and it just died. Everytime I would start it up it would just die again. It was -3 degrees F and I did have it plugged in overnight. Does anyone have any ideas? Thanks in advance for your help.
Old Jan 24, 2011 | 08:16 AM
BC847's Avatar
1st Generation Admin
Gelled fuel has plugged the fuel filter?
Old Jan 24, 2011 | 02:09 PM
mowin4dodge's Avatar
fuel
Are you putting fuel additive in it with the temp so low?
Old Jan 24, 2011 | 02:59 PM
Scotty's Avatar
Top's Younger Twin
Could be the lift pump. Check fuel pressure if you can. Check the fuel filter, if its gelled, then you need an additive. However, its not very common to have fuel gelling anymore.
Have not used an additive for several yrs now.
Old Jan 24, 2011 | 05:35 PM
st.rodder2's Avatar
Well finally was able to get the truck to start and move it into the sun for the afternoon. Put some diesel 911 in the tank and let it sit in the sun. Temps finally got up to 17*. Change the fuel filter didn't look bad. Truck is running again. Stuffed it into the garage with a heater going. We'll see how it runs tomorrow. Thanks for the help.
06RAM2500
Nov 2, 2011 01:46 PM
jdddually
Jun 16, 2011 09:18 PM
ado2b1
Jan 8, 2010 04:27 PM
tbrunson
Mar 11, 2009 07:35 PM
Firemanhoser
Dec 13, 2007 01:05 PM
