Truck stranded in San Antonio TX.
Old Oct 9, 2006 | 06:54 AM
Little-bit's Avatar
Thumbs down Truck stranded in San Antonio TX.
Transmission started making a howling noise and then I heard a pop! I pulled over and there was transmission fluid leaking every where. The transfer case split in half where the front drive shaft ties into it. What the heck? I was on I-10 and only driving about 60 mph. I live in Bay City TX. The truck is at a local dodge dealer there. I am waiting on an estimate to have it repaired. I may want to trailer it home from there. Does any one have any ideas as to what may have happened? Also any ideas for towing or trailoring from San Antonio..
Old Oct 9, 2006 | 07:29 AM
1-2-3's Avatar
Just a plain ole guy
How many miles? Any chance of warranty? Did you take you box off before the dealer got it?
Old Oct 9, 2006 | 07:54 AM
Little-bit's Avatar
Truck has 85k on it and the box is no longer there.
Old Oct 9, 2006 | 08:26 AM
Little-bit's Avatar
Does the transfer case seperate from the transmission?
Old Oct 9, 2006 | 11:08 AM
Little-bit's Avatar
I really need some help here guys. Has anyone seen this failure before? please post up, thanks.
Old Oct 9, 2006 | 12:29 PM
Little-bit's Avatar
Transfer case split in half.
Back to top.
Old Oct 9, 2006 | 12:36 PM
BigBlue's Avatar
Unless you had it in 4wd while you were driving I don't see how that could have happened. Sounds like something bound up and finally popped. Definately a freak event.
Old Oct 9, 2006 | 12:43 PM
whitebuffalo's Avatar
low on fluid or something maybe?
the transfer case is bolted behind the transmission.
im in san antonio, let me know if i can help out....
Old Oct 9, 2006 | 04:34 PM
Little-bit's Avatar
I appreciate the feed back. The dealer called me this morning the transfer case is definitely the culprit. It is indeed cracked. The dealer has never seen this before. They have no idea and I don’t either. When traveling down the road and not in 4WD the transfer case is not engaged. I spoke with a mechanic earlier and he told me that the front bearing has a retainer ring that holds it in the forward position. If the retainer ring comes out the bearing will float back and hit the gear the gear will thrust the bearing forward and possibly crack the case. Oh well the dealer wants $1800 to replace the transfer case. I found a couple of used ones for around $800. It would cost me around $450 to haul the truck to my barn to begin repairs. It is just isn’t worth it. I am getting disappointed in my dodge. Three months ago it was the injector and lift pump and now this.
Old Oct 9, 2006 | 06:22 PM
BigBlue's Avatar
Well you can rest easy in that once this one is replaced you shouldn't have this problem again. You definately had a freak of nature thing happen to you.
Old Oct 9, 2006 | 06:48 PM
scottsjeeprolet's Avatar
I am sorry to hear of your delemma. if i was in Texas i would help a brother out.
Maybe one of our great members will volunteer to tow your rig home. Might cost ya a case of beer and fuel.
Old Oct 9, 2006 | 06:53 PM
crobtex's Avatar
This is not covered under warranty?
Old Oct 9, 2006 | 06:58 PM
crobtex's Avatar
Oh, I forgot to ask. If you're in Bay City, any chance you're going to the races on the 14th? If you do, stop by the ODRA tent and ask where the DTR guys are. Who knows....we might even have a cold one laying around, if you're so inclined.
Old Oct 9, 2006 | 10:38 PM
with 85k i would think it shoukd be under warranty.
if i had my trailer im looking for id tow u home.....havent had any luck finding one yet.....
edit: nevermind, im an idiot. 100k is on engine only.
Old Oct 10, 2006 | 10:30 AM
Redleg's Avatar
I think a Jasper runs $1000-$1200. Maybe somebody local can find a Jasper installer that has or can recommend a tow service to pick it up. It'll probably last longer and have a better warranty that the OEM.
