truck not starting ?
i have a 98 24 valve truck and just had the injection pump replaced and lift pump and everything was fine but now when i try to start the truck after long period of sitting it takes while for it start like its not getting any fuel but if i let the lift pump run through cycle it starts right up . i took it to local shop and they said that i might have faulty injection pump but i dont think thats it if you have any suggestions it would help thanks
The first place to start is by making sure you have new or near new flexible fuel lines from the tank to the frame lines, and from the frame lines to the engine.
They all develop air leaks after a few years and will allow the fuel to bleed back to the tank. Then you purge the fuel system and all is good until the next time you shut down and let it set for a while.
fourthandgoal
88
Dec 27, 2011 05:39 AM
CRYSTALCRYSTAL
Jun 4, 2008 05:23 PM
abc4yew
Mar 15, 2007 11:55 PM
