Truck is making oil again!!!!!
Old Apr 30, 2008 | 03:52 PM
Big T's Avatar
Well if I could sell it it would not be a bad thing. Last year replaced injectors when it was filling up with oil. April 17 took it in oil on the rise they checked everything no leaks. They drained down oil to the right level now it is in the #`s on the stick again. It doese not fill up quickly like a bad injector would, but it is just a steady little increase. Any body have any suggestions truck will be going in tomorrow.
Thx Big T
Old Apr 30, 2008 | 04:13 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
A motor can't "make" oil. I'll bet you still have a leaky injector. I'm not too familar with the CR injectors, but an injector o-ring could be letting just a minute amount of fuel to pass into the head, which would cause a "raise" in oil level.
Old Apr 30, 2008 | 04:39 PM
JPR Ram's Avatar
OR, I hate saying this, how does your anti-freeze level look? Is it low?
Old Apr 30, 2008 | 06:34 PM
garbri's Avatar
Leaking anti-freeze generally results in a milky-white oil.
Diesel mixed in with the oil looks like thinned out oil.
Do you operate your truck around town on many short trips? Do you idle excessively? Incomplete (ie, cold) combustion leaves unburned fuel that finds its way to the crankcase.
Lots of extra oil can be a sign of a leaky injector.
garrett
Old Apr 30, 2008 | 10:26 PM
Big T's Avatar
I do spend more time on short tripps, but I know alot of people do. How can they make an engine that will wash the cylenders out? the last time I took it in the service rep told me to run it harder, I heave been. But I know others out there have been running easiere do to fuel cost: i was told by my service rep ( goood friend) that he has never seen a truck run so eazy. Bot at a $4.50 a gallon I am not florring this beast. Could a ring or somthing else be wrong, or can an injector just leak a little instead of filling the crank when an injector blew lik ethe first time?
Old May 1, 2008 | 01:52 PM
Big T's Avatar
Anybody else!!
Old May 2, 2008 | 09:54 AM
Snapper's Avatar
Ms. Daisy, I need to make Water... sorry had to interject that in there
Old May 2, 2008 | 10:38 AM
The Hog's Avatar
bottle it up! have you seen prices on oil? wish i could make some.
Old May 2, 2008 | 02:15 PM
johnh's Avatar
time for a new truck
Old May 2, 2008 | 04:32 PM
Busboy's Avatar
Try running some injector cleaner through....... if you really baby the engine maybe it carbons up badly.
Old May 2, 2008 | 05:05 PM
gandalf1g's Avatar
My vote is for the oring leak off the common rail.
Old May 2, 2008 | 09:08 PM
dudiesl's Avatar
the trans drop braket for your lift will make your oil look more fuller than it really is.i know went though the same thing
burlhall
Jul 13, 2011 08:40 AM
Steven K
Jun 4, 2009 10:32 AM
realoldandcrust
Feb 14, 2008 09:53 AM
b84u
Feb 20, 2006 01:04 PM
Sean S
Nov 15, 2002 12:25 PM
