Truck is hard to start in the morning
Old Jun 8, 2005 | 06:14 PM
haulywood's Avatar
Red face Truck is hard to start in the morning
Every morning I try to start my truck it is very hard to start and I have to keep pumping the pedal to finally get it to turn over and then it will run ruff for a minute and white smoke comes out of the exhaust pipe and then it will smooth out and run good all day HELP.
Old Jun 8, 2005 | 07:02 PM
phox_mulder's Avatar
Welcome to the site.
Need a little more information.
Year, make, and model to start.
12 valve or 24 valve or 3rd gen.
phox
Old Jun 8, 2005 | 07:37 PM
haulywood's Avatar
Its a 1995 Dodge 3/4 ton 2wd diesel 212000 miles
Old Jun 8, 2005 | 07:45 PM
haulywood's Avatar
Thank you I have looked all over for a site like this with Intelligent people who have a clue 1995 Dodge 3/4 Diesel 12 valve with 212000 miles
Old Jun 8, 2005 | 10:54 PM
Sorry, I don't know that much about the undervalved engines,
but I guarrantee someone will be along all full of knowledge.
For future posts, it is recommended that you fill out your profile with pertinent truck info, then it will show up each post so you don't have to keep telling people what you have.
Click on "user cp" button up above the posts, then "edit profile".
'Bout halfway down the page you'll see a signature box, put the truck info in there, the click "submit modifications" at the bottom of that page.
You'll see my sig beneath this post to give you some ideas.
phox
Old Jun 9, 2005 | 06:34 AM
Smokee's Avatar
The [problem will probably be leaking rubber fuel lines. The lines may not obviously be leaking fuel, but they will be drawing air as the engine cools.
If you look at the engine from the driver's side, the lines run behind the fuel filter.
The repacement isn't easy, but it is cheap. I recommend that you replace both supply and return lines with diesel rated hose all the way to the tank.
Good Luck
Old Jun 10, 2005 | 05:56 PM
NO1B4ME's Avatar
Lines................
Check the top of Your tank at the module for rusted or broken fittings, also check the lines from the tank straight to the engine, gotta be a leak somewhere. Just went through this awhile ago, what a PITA.
bert01ctd
Oct 4, 2007 04:10 PM
99turborock
Feb 4, 2007 12:04 PM
wadecool
Sep 5, 2006 08:12 AM
12valve
21
Dec 2, 2005 11:56 AM
yrusoslow2
13
Feb 17, 2004 03:43 AM
