hard start in morning
Old Sep 1, 2006 | 02:53 AM
wadecool's Avatar
My truck has just turned over when I try to start in the morning. After I bump the starter and wait for LP to quit, it'll start after 5 or 10 seconds of cranking and will start and run fine all day. I have 198k now, had IP and LP(in tank) replaced under warrany at 95k. I've been running a superchips tuner on low(towsafe) setting, but I turned it back to stock til I figure out my problem. My problem srarted when I'd leave it parked on a hill overnite, but it has also had hard starts on flat ground. I've had a constant drip/leak from the water separator valve, but I replaced it today, no more leak. What do you guys think? Do I have an airleak somewhere or is it something else. I've been checking my FP with a portable gauge on the IP schrader valve and get 10 at idle, 5 or 6 at WOT. Any help will be greatly appreciated. Thanks for all the valuable info you guys put on this site!
Old Sep 1, 2006 | 03:51 AM
Viperdew's Avatar
Originally Posted by wadecool
Thanks for all the invaluable info you guys put on this site!
Wow! what a great way to get a response or help! Invaluable or did you mean Valuable ??
Old Sep 1, 2006 | 03:59 AM
Viperdew's Avatar
When was the last time that you changed your fuel filter? Good thing that you found the leak and fixed that. There could be a some air in the line but after cycling the pump several times that should fix that.
Old Sep 4, 2006 | 06:58 AM
Bigdenny's Avatar
I had the same thing happen to my truck, I put in a one way check valve just brefore the vp44 and it fires right up everytime. Fater in-law owned truck before me and had the truck at 3 to 4 places including dealers. no body could fix it. I, being a master tech figured that the vp44 was draining fuel back. so When I got the truck I put a inline check vavle and it works great. Den
Old Sep 4, 2006 | 07:08 AM
Geico266's Avatar
Without a fuel pressure guage you probably burned up your second IP. Just hearing the LP run does not mean it is working good enough to cool the IP.
Get a guage.
Old Sep 4, 2006 | 08:14 AM
dieselfan's Avatar
my truck is also hard to start, i pulled the power to my holley blue just for a second to see the fuel psi with just the factory lp and it said 0psi .
so i hurry up and put it back and 23psi . this is a NAPA lp that cost $200 plus. it is only 6 months old and 8k miles on it. if i didnt have that holley blue, my 2nd VP44 would be gone. do yall think i hurt my vp44? the psi has been 21-24 @idle 17-19 cruising and sometimes 12psi at WOT. i also just changed my fuel filter just to be sure, it looked fine, it'd had only been about 3k-4k miles since the last time i changed it. sorry for threadjacking.
thanks brian
Old Sep 4, 2006 | 08:20 AM
new2ctd's Avatar
Invaluable means priceless or beyond calculation.
So he is rightly showing an appreciation for the folks on this site.
Old Sep 5, 2006 | 08:12 AM
wadecool's Avatar
Ihave been checking fp at the schrader valve on the IP with a temporary gauge from autozone. It is 10 at idle, 5 to 6 at wot. I don't know how to check fp on the in tank LP. Anyone know how?
bert01ctd
Oct 4, 2007 04:10 PM
99turborock
Feb 4, 2007 12:04 PM
12valve
21
Dec 2, 2005 11:56 AM
haulywood
Jun 10, 2005 05:56 PM
yrusoslow2
13
Feb 17, 2004 03:43 AM
