Truck Is Down Need Help
Old May 31, 2006 | 09:41 AM
KITCHEN's Avatar
Ecm Shut Down Fuel Pump-wait To Start-running In Limp Mode.... Now Have New Ecm And Pump-wait To Start Work Great But Truck Still Runs Rough Like In Limp... Codes Are 253 252 251 Thanks
Old May 31, 2006 | 10:10 AM
crobtex's Avatar
We need to know what kind of truck you have, etc.
All three codes are injector pump related. Have you tried to reset the codes and see if they go away. If you don't have the use of a scan tool, disconnect the ground cable on BOTH batteries, turn the key to the "on" position, and let it set for an hour or so. Then, turn the key off, reconnect the batteries and try it again and see what it does. You're injector pump is going out, but there is a chance it might just be a fluke that set the codes.
Good Luck,
Old May 31, 2006 | 10:18 AM
KITCHEN's Avatar
98.5 24v Vin 6 2500 Auto........cleared Codes With Scanner..turn Ign. On No Engin Light Start Truck Engine Light On... Same Codes..
Old May 31, 2006 | 10:26 AM
crobtex's Avatar
Hmmmm, Most likely the injector pump bitting the dust or ECM shot. I'm afraid you'll have to take it to a dealer () or diesel shop to have it checked. If you have good fuel pressure to the IP, that's PROBABLY about all it can be, considering the codes.
Old May 31, 2006 | 11:22 AM
KITCHEN's Avatar
Do You Know The Discription Of Those Codes 253 252 251...and Do You Think Just A Few Miles With Out A Lift Pump Would Trash A Vp44?
Old May 31, 2006 | 11:58 AM
crobtex's Avatar
P0251 - Injector Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 - Injector Pump Fuel Metering Control "A" Rang/Performance (Cam/Rotor/Injector)
P0253 - Injector Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
I can't translate these for you, but it has to do with the VP44.
There are a lot of VP44 tales on here. Some say they were OK after a few miles with a dead LP, and others say theirs died with no warning. No easy answer for that one............
Old May 31, 2006 | 12:19 PM
P.J's Avatar
P.J
Depends.
If it is dead, but still allowing fuel to pass it may not kill anything (in the short term).
The safe answer is YES, you will kill your Injection Pump without an operable LP.
nbanner
13
Sep 6, 2012 12:51 PM
NOSTROKER
Mar 13, 2009 10:49 PM
Krob
Nov 3, 2008 04:39 AM
wpzone
Feb 21, 2008 06:49 AM
