trouble code
Old Sep 23, 2006 | 03:49 PM
herb's Avatar
trouble code
Have my new 06 truck hooked to the trailer and am ready to pull out for a coast to coast run early in the morning.
Went over to put my luggae ect in the truck and found the key had been left on and the batteries dead. Hooked the battery charger to it for 15 minutes or so and it started right up.
Now I have the check engine light on, i unhooked the battery cables for 1/2 hour reconnecte and light is still on (continues to stay on when running)
pulled a code of 2509
P2509 ECM/PCM Power Input Signal Intermittent
what to do ?
Old Sep 23, 2006 | 05:34 PM
herb's Avatar
what to do ?
Bump---how about some input on this one---getting dark outside
Old Sep 23, 2006 | 05:45 PM
Shovelhead's Avatar
Administrator / Scooter Bum
It could just be a stored code that's keeping the light on.
I've had that happen before, and 10 or 15 engine Start - Shut Down cycles and the light went out.
Went over to put my luggage ect in the truck and found the key had been left on and the batteries dead.
We tried to warn you about listening to the Dixie Chicks in the truck all night long......but would you listen to us.......Nooooooooo.....
Old Sep 23, 2006 | 05:51 PM
herb's Avatar
Be Nice !! I switched between the Chicks and Willie.
Old Sep 23, 2006 | 06:09 PM
That's not a code I would worry about. Seems pretty clear that it was caused by the battery dying with the key on. Somebody with a scan tool can clear it, but it will go away after a few starts - 35 I think.
Old Sep 23, 2006 | 06:25 PM
herb's Avatar
Thanks--- wouldn't wanna give me your phone number to use in case Ibreak down would ya ??
Old Sep 23, 2006 | 06:27 PM
If you're headed my way I'd be happy to help you out.
Old Sep 23, 2006 | 06:41 PM
herb's Avatar
This trip is Colorada-Calif and Arizona -- Next trip is Idaho and Montana--Next trip is Ma and NY so could be limping by then
See why I install the Air Ride Seat ??
ridlangus123
Dec 30, 2013 08:36 PM
j
Mar 9, 2004 11:45 AM
fitzer
Mar 7, 2004 07:09 AM
sawboywv1
Jan 5, 2004 04:42 PM
dansdodgediesel
Jan 2, 2004 04:30 PM
