Trouble with 4 wheel drive
Old Jan 23, 2007 | 03:05 PM
premo 1's Avatar
From: St. Louis, Mo Home of Busch& Budwiser Beer and Kurt Warner---opps I mean the RAMS
I am having problems with my 4 wheel drive
When I shift the lever into 4 wheel drive it takes a good amount of time to go into 4x4, the lite on the dash flickers on and off, and then goes into 4x4
When the lite is off, it is in 2 wheel drive.
When you move lever from 4x4 to 2 wheel drive it is done quickly.
Old Jan 23, 2007 | 03:16 PM
AggieJustin's Avatar
I'd check the vacuum lines going to the transfer case and front axle. It's possible you have a minor leak in one of the lines that engages 4WD that causes the front axle to not positively engage right away.
Old Jan 23, 2007 | 03:27 PM
PaulDaisy's Avatar
I find that it I go into 4wd while driving, it may take a little while to engage but if I let off of gas and coast, it engages right away. I think the reason is, the collar pushes against the splines just a tad while the axle is being rolled and once the axle is decelerating, the splines must align better. Disengaging takes a bit on mine too and if the axle is under load (like parked on an incline), it will only disengage after it rolls and the load is off the axle.
-P
Old Jan 23, 2007 | 04:19 PM
farmer dave's Avatar
I would also look at your vaccum lines to make sure there is no leak.
Old Jan 23, 2007 | 05:39 PM
XLR8R's Avatar
Ditto - check the vacuum lines & solenoid.
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
