transfer pump???
Old Jan 15, 2003 | 05:21 PM
dodgeme's Avatar
transfer pump???
???what is a transfer pump and what signs would it give when going bad? could this be the only thing wrong or will this lead to other problems with my '01 HO 6-spd?
Old Jan 15, 2003 | 05:51 PM
AlpineRAM's Avatar
Re:transfer pump???
Search for lift pump on this board. Lots of threads about it.<br><br>AlpineRAM
Old Jan 15, 2003 | 06:16 PM
rich's Avatar
Re:transfer pump???
the best way to check it is to get fuel pressure gauge and check the pressure. You can also listen for it to buzz but that doesnt mean it is working to its maxium requirements. The one on my 01 lasted to 95k. It is the pump under the fuel filter and it supplies the vp-44 pump without it your injection pump will die
Old Jan 16, 2003 | 10:45 AM
dodgeme's Avatar
Re:transfer pump???
thank you all for the info. I did have the truck at a dealership when I asked about it. it is still covered under warranty for now so hopefully this won't be a problem again, any views on this? will this probably go bad again? My first Dodge was a '92 3/4 ton 5 spd. I had that truck for 7 years and the only thing I EVER had to fix (or replace) was the clutch. never had a problem with anything else (except speedometer quit working and I never got that fixed) so this newer truck will take some getting used to!
Old Jan 16, 2003 | 07:38 PM
Stamey's Avatar
Re:transfer pump???
Yes, it is possible that you will continue to have problems, although there's no predicting if or when. Some people have had them replaced 3 times before 20K and some people have run them out of warranty without a single problem. More the former than the latter, I suspect. See the threads about lift pumps and pucher pumps in the Aftermarket forum.<br><br>Chris
Old Jan 17, 2003 | 07:04 AM
TXRAM2's Avatar
Re:transfer pump???
Yes what everyone said above. Best insurance is to have a pressure gauge, either in the cab or at least a test gauge. Then you can watch the psi and have warning when it is starting to fade away. Pressures should be:idle-14-15psi, cruising empty 10-11psi, and wot not below 8psi. Keeping good fuel flow will allow you vp44 to live long and happy. With out good fuel flow it will die a long and miserable death.<br>IMHO you have to watch fuel pressure as most trucks will run just fine with almost no pressure.<br>my $.02<br>wk
gopokes
Jun 28, 2007 12:51 PM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
muddslinger
Nov 28, 2005 11:33 PM
