Trans won't shift into OD
Old Jun 13, 2003 | 05:57 PM
Drafter's Avatar
As of this morning my truck will not shift into OD. I have scheduled a warrenty service call for Monday morning at the dealer I bought it from to take care of this problem.<br><br>My question is it ok to drive it for extended periods of time at 2,500 RPM. I have some driving that I have to do this weekend and I could possibly use another vehicle if you say not to drive my truck. I'm kind of thinking that the only thing that will suffer is my fuel mileage but I want to make sure first.<br><br>Thanks
Old Jun 13, 2003 | 06:27 PM
MnTom's Avatar
Re:Trans won't shift into OD
No, you won't have a problem at that rpm. If you are like me, I have a hard time running it like that. I don't like the sound above about 2100 rpm. I am on ex truck driver and it was drummed into my head &quot;Keep the rpm between 1500 and 2100&quot;. I also have to put the pedal close to the floor for that high of rpms.<br>Tom
Old Jun 14, 2003 | 02:17 PM
RCW's Avatar
RCW
The engine can easily handle the rpm. Fuel economy will suck!<br><br>I have one of the new 03 automatics used in a commercial agricultural business with over 78,000 miles, and zero problems, so would be real interested to know what the dealer tells you.
Old Jun 14, 2003 | 03:14 PM
Drafter's Avatar
To add to my woes I found out this morning that the cruise control will not work either. When I push the cruise on button the readout does not light up. Not sure if these two things (cruise and OD) have something in common but I will post whatever the dealer says was the problem and how it was fixed.
Old Jun 14, 2003 | 10:47 PM
CRT's Avatar
CRT
Sounds like the Throttle Position Sensor could be bad.
Old Jun 14, 2003 | 11:29 PM
DF5152's Avatar
or the speed distance sensor...
turfguy
Dec 29, 2009 08:29 AM
nathan04
Dec 13, 2007 10:12 PM
95ram
Jul 9, 2007 01:50 PM
perk
Jan 30, 2003 07:10 PM
Nicholas
Dec 24, 2002 06:02 AM
