Trans Fluid?
Old Aug 3, 2005 | 05:19 PM
Reel Native's Avatar
Trans Fluid?
Can anyone tell me if Mopar Type III and Type IIII trans fluid is interchangable
Old Aug 3, 2005 | 06:09 PM
rockwithjason's Avatar
Yes they can be used separatly or together.
Old Aug 3, 2005 | 06:11 PM
chasd60's Avatar
No they can not. ATF+4 is for the newer vehicles. I have a 2001 and it specifies ATF+4. ATF+4 isbackward compatible but ATF+3 is not forward compatible.
Link to a TSB
http://dodgeram.info/tsb/2004/21-004-04.htm
Old Aug 4, 2005 | 12:09 AM
J BODY's Avatar
If you are refering to the 05 in your sig, use +4.
Old Aug 4, 2005 | 02:49 PM
RAM2940's Avatar
You can put 4 into a tranny with 3 but you should not mix 3 into a tranny with 4. Or you can go up but can't go down.
archer39
Dec 5, 2009 07:40 PM
mar67655
Mar 14, 2009 07:22 PM
nfsommer
Nov 9, 2007 09:36 AM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
