tranny help
Old Feb 22, 2007 | 12:31 PM
THE 0NE's Avatar
tranny help
hello i live in the bay area and i need some help with my 48 RE, it started to slip after 4 months i had a place in az build it to their specs but no it has started to slip and the shop i took it to wont touch it cause it is aftermarket. it is a 2003 dodge 48 RE with a stall converter..... thanks
Old Feb 22, 2007 | 03:47 PM
bdewey's Avatar
Did it have any type of warrenty when you got the tranny.
Old Feb 22, 2007 | 05:16 PM
THE 0NE's Avatar
yeah but the company is giving me the run around. i am trying to solve the problem with them but they are no help..
Old Feb 22, 2007 | 05:26 PM
dieselrob's Avatar
Search for suncoast transmissions they can help you.
Old Feb 22, 2007 | 09:00 PM
J BODY's Avatar
Would that be the Ebay store that sells trannys out of Phoenix?
Trans slipping? or torque converter not holding the power?
What is it doing exactly?
Old Feb 23, 2007 | 03:09 AM
THE 0NE's Avatar
YES ITS THAT EBAY COMPANY and it feels like it slips when it is in drive but if i put it thriugh the gears it feels fine. i think it might be taking off in second???
Old Feb 23, 2007 | 07:30 AM
J BODY's Avatar
A real "pig" when taking off from a dead stop? When you take off pull the gear selector down into low and see if it "bumps" down into second. You may have a governor transducer/solenoid issue. Those are "usual" suspects when your trans goes into "limp in" mode and takes off in third.
Old Feb 23, 2007 | 11:32 AM
THE 0NE's Avatar
yeah thats how it feels if i bump it down it runs fine....thanks i am going to a new solenoid and see if that works.. thank you
Old Feb 23, 2007 | 08:20 PM
J BODY's Avatar
replace the solenoid and transducer.
rjweiss
Jun 4, 2011 07:48 PM
Black Dog
Dec 3, 2009 08:18 PM
4doogie
Dec 15, 2008 12:37 PM
davelinde
18
Jul 14, 2008 08:34 PM
Common
Jun 9, 2008 12:16 PM
