Too much PSI???
Old Jul 30, 2006 | 06:51 PM
Tayloe08's Avatar
Too much PSI???
Trying to rid fuel pressure issues inexpensively by adding a stock LP near the fuel tank. I got all my hoses and fittings plus a bracket and begin the install. After installed and system primed I started the truck and almost pegged my 30 PSI FP gauge (28 PSI)!! Let the truck run for a little while and noticed about $30 dollars of diesel fuel under the engine. There was diesel spraying out around the top of the fuel filter. I think my gasket was streched to begin with but would that much pressure hurt a new gasket?? Of course I could only get an idle reading but is 28 PSI too high? Thanks
Tayloe
Old Jul 31, 2006 | 10:34 PM
blackdiesel's Avatar
Registered
did you change your fuel filter? if you did, did you replace your fuel canister lid gasket? make sure you didnt cross thread the cap and get it tight, but not too tight.
dieselJon
Jan 3, 2011 08:18 PM
tanderson2002us
21
May 14, 2009 03:49 PM
jjrightmire1973
Nov 20, 2008 08:20 AM
natlchamp2k4
16
Oct 26, 2006 04:41 PM
Cumminsdieselboy
Aug 25, 2003 01:56 PM
