Tons of white smoke!
Here's my problem... 1999, auto, starts and idles fine but intermitent sputtering, sounds like it's running with a couple cylinders out when accelerating, especially at about 20-30 mph, lots of white smoke until I let off of it then it smooths out. LP?, fuel filter?
as cold as it is, i would say fuel filter/gelling fuel. Did you check your codes and can you here your lift pump running? dont start your truck just bump the starter and leave the key in the on position, you should here it buzzing for about 10 sec or so. If you have a garage put it in there with some heat. With the fuel heater it shouldnt gell but it may not be working. Post if you have any codes.
Doesn't work on the 99's . I'd bet on gelling too. Get a bottle of the 911 ( red bottle) power service. If it will run, change the filter and add the 911 to the tank. Depending on how much fuel is in the tank, probably the whole bottle. Let it get warmed up, and give it a try.
ditchbangin
Dec 24, 2010 04:34 PM
89dieselkong
Dec 5, 2010 04:48 PM
niekrewb
May 8, 2008 09:19 AM
