Throttle return spring
Old Nov 17, 2003 | 06:22 PM
dieselroamer's Avatar
Anyone,
On my way home tonight, it seems as though a spring that helps the throttle return to the closed position came loose from one of it's attachment points (please excuse the technical jargon!) The throttle doesn't stick open when you put the pedal down, but it doesn't return to idle very quick if you put the clutch in and leave it for a sec but it will in a few seconds. Got under the hood and found the spring dangling from one end. My question is, where does it attach to? I have it attached to a small bracket that provides enough tension on it to return it back to the closed position but I don't think its the correct way to do it. It's got a small hook that doesn't look like it's going to hold to well in its current location and I don't want to have to keep re-attaching it! It's a '94 SLT.
Thanks for your help!
Old Nov 18, 2003 | 07:20 PM
RCW's Avatar
RCW
Re:Throttle return spring
The main throttle spring end connects to the lower bellcrank at the back of the throttle rod, and down by the power steering filler on the front end. If you look near the bottom of the power steering filler neck, right above the tank, and on the engine, you will see the bracket for the spring's hook.
Old Nov 18, 2003 | 07:39 PM
Rattlerattle's Avatar
http://www.dodgeram.org/tech/dsl/Fac...ocations-l.gif
Diagrams are always better than me trying to describe it!
On mine the hook on the end of the spring broke off! From the dealer it was $8.00 Cdn. Easy to replace when you see where it has to go back on.
;D
Old Nov 18, 2003 | 10:15 PM
Gentleman,
Thanks you very much for your help. I will give it a shot tomorrow after work. The GIF file is of tremendous help too.
Rattlerattle, what shops are around Vancouver that you would recommend visiting? I'll be up there around X-Mas (my wife is from the mission/maple ridge area) and thought I might kill sometime checking out some shops and products as opposed to hanging around with the in-laws. Seems like there are a few shops in Abbotsford, no?
Thanks,
DR
Old Nov 19, 2003 | 06:34 PM
Couple of the big ones are Piers and BD / Valley fuel.
Old Nov 19, 2003 | 06:43 PM
Captain's Avatar
I've replaced both of those springs on each of our trucks. I guess they have a habbit of snapping? There cheap from the *******. We each keep an extra in our trucks now. It takes all of 30seconds to install. If you have any unanswered questions still just PM me
Chris
Old Nov 24, 2003 | 02:21 AM
Bushy's Avatar
Patron Saint of 1st gens
dieselroamer,
Drop in and see us at Piers Diesel Research (PDR) when you come up.
I live in Maple Ridge myself and would be glad to have you stop by the shop while you're up...
We're located in Port Kells (Langley) and the toll free number is: 866-888-9396.
Bob ~ PDR ~ BLack SHeep RAcing..
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
Roll'n Coal2010
Mar 18, 2010 01:41 PM
ctd4stan
May 18, 2009 02:56 PM
TIMMY22
Nov 22, 2006 07:02 PM
