the in tank fuel pump is dead...
Old May 22, 2009 | 11:22 AM
dodgedude361's Avatar
is there a bolt on aftermaket pump that can pull fuel through the dead one? looking for a quick ez fix here.
tia
Old May 22, 2009 | 04:08 PM
Jeff in TD's Avatar
I could be wrong, but I thought when the 3rd gen lift pumps die, they usually won't let fuel be drawn through.
Old May 22, 2009 | 06:20 PM
J BODY's Avatar
Interesting...... I have yet to see one dead.
Old May 22, 2009 | 09:47 PM
yea, at 130,000 miles she is dead. there is a nationwide backorder of over 2 weeks for a replacement.....
Old May 22, 2009 | 11:22 PM
annabelle's Avatar
I've had two die.
Old May 25, 2009 | 09:52 AM
patdaly's Avatar
I can send you one I have saved up.......
Old May 25, 2009 | 10:19 AM
scottsjeeprolet's Avatar
Air Dogs are still on sale for $499.
Your gonna have to drop the tank no matter what. Get the AD150 and the new canister plumbing and be done with it.
Old May 30, 2009 | 04:31 PM
J BODY's Avatar
The only two "dead" in tank lift pumps I've seen were wiring issues.
One a guy bought from a used car lot. Truck died out in the desert. Got towed in... There was no FUSE in the fuse holder for the in tank pump. Customer had some other electrical issue with the truck and the used car lot "mechanic" pulled the fuse out. They thought it was for some kind of aftermarket alarm or something. Good thing they didn't cut the wiring and remove the relay too.
Other one would die intermittantly. Duplicated the prob and found the filter housing only half full. Found that one had a corroded connector up toward the front of the truck that caused high resistance on the ground side of the pump. Added a new ground and it was good to go.
Not saying they will "never" fail, but for how long they have used the in tank pump now, and the amount of non failures I've encountered, I'm pretty much sold on them.
Old May 30, 2009 | 05:37 PM
annabelle's Avatar
Mine were the pump motor......not the wiring. Each lasted about 90,000 miles.
Old May 31, 2009 | 12:24 AM
annabelle's Avatar
I was wrong.......after checking my records, the original firewall mounted FP went out at 128,000 miles. The in tank replacement (dealer installed) went out 91,000 miles later. I know of several folks who have lost the in tank version. No wiring problems.....just dead FP.
Stamey
Jun 27, 2008 02:04 PM
ramsport59
MDDTR #33
Feb 21, 2008 04:15 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
