tail 4ways and turn lights out
Old May 29, 2005 | 12:01 PM
DocCJV8's Avatar
Question tail 4ways and turn lights out
:confused: ok driving home on the hight way and my problems start. I got a 93 Dodge Diesel 1 i lose the dash lights, pull over and check the tail lights....none check the fuse blown-replace the fuse it good and does not blow recheck lights none. ok 4way on and drive home. they go out wife is giving me dirty looks now knows im going to start in about how nice a 2005 would be. 4ways go out and im quick to turn them off and hit the trun signal and pull over sitting ther checking the fuse box again i hear the trun signal flasher stoppes look on the dash no turn signal ok turn on the arrowstick it works. nextel a friend dealer teck he has no idea and tells me that they dont have any tecks good at electrical that he would trust.
some things done to the truck plow light with factory tap in for the plow and 2 different trialer plugs that have been on the truck from new everything I have added was ran with a different fuse box off the battery, nothing tied in to the factory wiring. everything has been on this truck from the day i bought it new in 93:confused: :confused: [deadhors]
Old May 29, 2005 | 12:06 PM
DocCJV8's Avatar
oh forgot to add the plow lights are off and I am lookind for a wiring diagram for the truck and any ideas on what to look at inside the truck, I'm removing all the trailer wiring and going to replace it does Dodge run all these lights through the turn signals control switch on the steering wheel. any help or two cents would help... thank guys
Old May 29, 2005 | 01:14 PM
apache's Avatar
Sound like what happened when my headlight switch went bad, go figure??
Old May 29, 2005 | 02:19 PM
DocCJV8's Avatar
I have replaced the head light switch about 6 monts ago. I was headed to a the Firehouse when it went just glad it was 3am and i was close and had 2 other guys around me so i kept going the last half mile. they started blinking and then went out all the way.
Diesel Junkie
Dec 23, 2014 03:01 PM
Jim Lane
May 4, 2010 08:45 AM
PCM
Nov 11, 2008 08:25 PM
rdmartin108
Aug 19, 2007 08:06 PM
CHarlan
Aug 6, 2003 08:40 PM
