strange tranny behavior from dead stop!
Old Feb 2, 2006 | 02:17 PM
mr T's Avatar
i come to a dead stop and i let off the brake and give her some light gas to get going...and just in that split second where it starts to move it kinda "downshitfs" or "slips" in order to engage to the gear and get going.....the truck doesnt rev and not move or anythign like that...its more like when i get my foot off the brake its still in 2nd and just as i start rolling it will kinda downshift and et going normally...its very subtle....otherwise the tranny shifts and drives awesome...lockup is awesome...fluid gets changed routinely.....i was wondering if this is a typical band adjusment canditate? i have never adjusted the bands or touched them since ive had the truck
Old Feb 3, 2006 | 12:38 AM
Rare1's Avatar
Common problem. Do a search. Question has been answered many times.
Old Feb 3, 2006 | 06:18 AM
P.J's Avatar
P.J
Governor pressure sensor (or is it selonoid?) Not an expensive part. I learned the hard way, the dealer decided I needed a whole new throttle body, $1,200 later my truck was back on the road for about $975.00 more than it should have cost.
Old Feb 3, 2006 | 06:26 AM
j-fox's Avatar
His truck has a hydraulic trans.
It is not dropping to 1st until he lets it roll forward, if I read it correctly.
Tell us about the Valvebody mods.
Old Feb 3, 2006 | 07:51 AM
mr T's Avatar
47RH....i have no valve body mods...i remember infidel saying that u only need to really think about adjustign bands when ur slipping in 1st or reverse...this doesnt happen all the time...i just wanna make adjustments where needed before i get bigger issues
Old Feb 3, 2006 | 08:00 PM
j-fox's Avatar
The bands are used in 2nd and reverse. None used for 1st.
Check the governor pressure. It should drop to 2 psi or less when coming to a stop.
Old Feb 4, 2006 | 11:28 AM
DIESELRYAN3500's Avatar
Tps ????.......worked For Me On Our '92 Auto.
Ryan
Old Feb 4, 2006 | 05:20 PM
mr T's Avatar
thanx for the reply ryan...its not the TPS...all shifts are fine ...lock-ups are fine too
Old Feb 5, 2006 | 03:07 PM
js's Avatar
js
had the same problem with mine about 6 years ago. went to the dealer for repair and ended up doing about $2500 plus in repairs. still think i got hosed but what can you do. ended up with new torque converter and other repairs to the tranny. I was told after that to not idle truck in park for any length of time. A friend in the oil field said they had mega problems with the fleet trucks that idled alot in the far north in the winter. same kind of shifting as you describe and i had. company did some research and discovered that no fluid circulates when idling in park. since then when idling put their trannys in nuetral and no problems. I done this for the last 6years and mine is just like new and no problems. seems idling took out sone seals or something because of lack of lubrication.
don't know if this is your problem but it sounds like what i had.
hope yous is easier tofix and cheaper
Old Feb 5, 2006 | 03:23 PM
mr T's Avatar
its been driving fine now...it wasnt a major issue anyway...kinda made me think and reminded me of a very light wheel hop...diff fluid hasnt been changed in 3 years...thanx
imaybail
Nov 17, 2006 10:08 PM
mjsandt
Feb 6, 2006 08:47 PM
Patrick Campbell
Jul 8, 2005 07:51 AM
josh99
Sep 4, 2004 01:36 PM
rattle_rattle
Dec 15, 2003 02:59 PM
