Stranded in Oklahoma Thanksgiving eve
Old Nov 21, 2007 | 06:58 PM
herb's Avatar
Son just called in---down in Oklahoma---35 MPH wide open.
Codes
P2146
P1755
P0148
P2509
Changed fuel filter
Old Nov 21, 2007 | 07:03 PM
Chrisreyn's Avatar
where in OK?( and what truck?)
Old Nov 21, 2007 | 07:44 PM
scootertrash35's Avatar
what's going on herb?
Old Nov 22, 2007 | 06:27 AM
herb's Avatar
Son is down in Checotah Ok. Fueled at a Loves in Seminole and problems started shortly after---
Changed fuel filter twice and the second fuel filter is BLACK already. Called Loves and they said they could'nt address the issue until tommorrow morning when their district manager comes in.
Codes up after changing the second filter were
P0301
P1755
P0148
P2509
P2146
Old Nov 22, 2007 | 07:15 AM
bump...somebody help him with the codes
Old Nov 22, 2007 | 07:28 AM
jazz_kt's Avatar
P0301 cylinder #1 Misfire
P1755
P0148 fuel delivery error
P2509 ecm/pcm power input signal intermittent
P2146 fuel injector group 1 supply voltage circut
Old Nov 22, 2007 | 07:36 AM
herb's Avatar
Could these codes be thrown by dirty fuel ?
Old Nov 22, 2007 | 08:15 AM
herb's Avatar
We got a load of bad fuel on the last trip too.---anyone else expeirencing bad fuel or are we just extra lucky ? (both times the fuel was from Loves.)
Old Nov 22, 2007 | 08:45 AM
LFD2037's Avatar
Sounds to me like he lost/ is losing power &/or ground. Mine thru the 2509 along w/ a few other codes when I incorrectly unplugged a module. I don't think fuel would be at fault & throw a code that states multi. systems are showing power loss. This is all I can think of. Sorry I'm not more help & I hope everything works out.
Old Nov 22, 2007 | 08:56 AM
TRX24V's Avatar
BUMP, Is it the truck in your sig!
Old Nov 22, 2007 | 10:24 AM
herb's Avatar
Yes ---it is the 06 3500
Old Nov 22, 2007 | 10:35 AM
pind's Avatar
this should have been addressed by the 06 model year, but check the wiring harness to the A/C pump. The older 3rd gen trucks had a habit of wearing through the insulation on the wire going over one of the lines, causing a short that would throw multiple codes for no apparent reason.
The coolest part was, after reset, it was never the exact same list of codes twice. It would also throw the truck into limp mode, or cause a high idle issue, cylinder misfires, bad shifting, etc.
Not saying this is the solution, just something to look at.
Old Nov 22, 2007 | 11:36 AM
Bad Ramer Jamer's Avatar
I don't think it was happening on the 06,,but have him look for the chaffed wire mentioned above. It's worth a try. Here's the thread.
https://www.dieseltruckresource.com/...ad.php?t=81936
Old Nov 22, 2007 | 04:45 PM
linetrash75's Avatar
Well if he can make it to Bartlesville (HWY75), I've got a warm turkey dinner and some time to help.
Jed
Old Nov 23, 2007 | 04:13 AM
herb's Avatar
Well i haven't heard from him since yesterday morning so i am assuming he got it going and is on his way home..
Someone local where he was broke down came on to the scene and was a Dodge 12v guy who works on Dodge deisels at a local dodge dealership.
Was able to get him a couple more filters and a couple bottles of Howes fuel treatment.
Said he took two or three gal out thru the filter line and got him going. When i last spoke to him he said it was still running a little rough but thought it might straigten it self out.
