Stated Squekking now its Grinding!!
I have noticed a sqeek from the drivetrain for a few weeks now figurd it was a U Joint dying well today on the way to work it started a clicking sound and then a intermittent grinding coming from the the drivetrain at first it sounded like somthing was dragging on the ground underneath but upon inspection found nothing. Could this be the rear end failing or will a u sjoint make that noise also?
gonna call the shop in the morning and send it in but want as much info as possible before I do i have the H.O. with a 6 Speed and 3:55 gears 80,000 miles on it doesnt seem like the rear end should fail that new
what do you guys think??
Originally Posted by bluepuller
I have noticed a squeak from the drive train for a few weeks now figured it was a U Joint dying well today on the way to work it started a clicking sound and then a intermittent grinding coming from the the drive train at first it sounded like something was dragging on the ground underneath but upon inspection found nothing. Could this be the rear end failing or will a u joint make that noise also?
what do you guys think??Why'd you wait a "few weeks" to have it looked at?
And now your mad??
Seized u joints stress other components. Who knows what went wrong.
Edit: And to go along with the other thread....here's your sign.
I didn't look at your sig before I started this but I had a similiar problem once sounded like I was dragging a chain or something under the truck. It was the carry over bearing going out its hard to if anything is wrong with it by looking unless its just distroyed.
RammTuff i didnt Know i was asking for negetive comments kinda thought this was a forum where people help each other not where you have to defend your actions to others
I would have some else drive the truck slowly while I tried to locate the noise. It could be a u-joint, a hub bearing, a carrier bearing, or axle bearing. Really hard to tell. I would start there though.
the fluid is Grey .
Rammtuff -with this truck it has been one thing after a nother new injection pump lift pump dealership put that in the tank tps sensor 2 u joints and it seems since the injection pump and lift pump wetre replaced it has lost about 2-3 miles per gallon and a bit of power so yeah i am getting a little fed up
wakecrazy22ssv
Nov 13, 2011 02:28 AM
southpawslingr1
Jul 9, 2008 08:44 PM
cLAYH
Feb 6, 2004 10:59 AM
