Starting problems
Old Nov 10, 2006 | 06:51 AM
deadbroke's Avatar
Starting problems
I have a 96 and a 98 Dodge Diesel dually's. About 2 months ago, the 98 became hard to start, would crank a few seconds then start. Then it died once and didn't start again, hauled it to Dodge dealership, they said it needed a new lift pump. Replaced it, but truck was still hard to start. Now BOTH trucks won't start they both act exactly the same way. Crank, crank , crank and nothing. They both will fire right off with Eather (sp). Both run like scalded apes once started. I pull a horse trailer with both these trucks, and have no problems with power, once started. Any suggestions on what this might be?
Old Nov 10, 2006 | 09:33 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
sounds like your getting air into the fuel system somehwhere, but first check the fuel return pressure check valve on the fuel return line leaving the IP.
Chris
Old Nov 10, 2006 | 09:44 PM
chop342's Avatar
Chris
Old Nov 11, 2006 | 06:43 AM
XLR8R's Avatar
Check the rubber fuel lines which are known to crack and suck air.
Old Nov 11, 2006 | 09:05 PM
chop342's Avatar
i dont know how to explain my first post being on here twice?
Chris
Old Nov 11, 2006 | 11:57 PM
XLR8R's Avatar
Don't worry about it
Old Nov 12, 2006 | 11:41 AM
infidel's Avatar
Replace the rubber line in red below with 5/16" diesel rated hose.
You will need about two feet. Removing the fuel filter makes it easier, have a replacement on hand.
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
