starting issue...help soon please
i went out to my truck to go run an errand...i get in and start the truck and then after 10 seconds it shuts off..i try again and same thing..this happened 5 times in a row..and now it doesnt even even start, it just cranks over..i have a quarter tank of fuel left and batteries are fully charged, the truck is an 06 thats only 7 months old...i check for codes by doing the key thing 3 times and it says nothing...
please help and thanx in advance :-(
p.s. i live in miami, fl so not a cold weather problem its like 80F right now
Due to the high rail pressure " DO NOT CRACK AN INJECTOR LINE" as you can cause serious injury due to fuel pressure. If it's an 06 it should still be under warranty, call Dodge Customer Care and have them tow it to your nearest dealer for repair at no charge to you. Other wise just a quick question. Is your millage over 8-10K and if so have you ever changed the fuel filter. If not you might want to pick up a Fleetguard or Stratsphor filter and change it first to see if that cures the problem. If you buy from a truck stop filter is under $15 and 10 minutes to change, Dodge is $45 for filter and 1/2 labor to change, usually around $100 for filter change and not under warranty.
pcgym
Jul 14, 2010 03:42 AM
quadman20
25
Jul 6, 2007 06:56 PM
desertdieselboy
May 15, 2007 08:30 PM
