Stalling
Old Feb 18, 2009 | 07:36 PM
cowpokenate's Avatar
Stalling
I have a 1998 24 valve 3500 4X4.
My problem is with stalling. It fires right up then stalls after it runs for a few minutes. It's not consistent and hesitates at times while driving but not all the time. After it does stall it fires right back up. (It's not smoking)
Old Feb 19, 2009 | 12:23 AM
jnicewan's Avatar
sounds like its sucking air somewhere, check all the rubber lines first. and the clamps. then look at the fuel heater and filter housing.
Old Feb 19, 2009 | 09:52 AM
j-fox's Avatar
You are new to these sites.
24 valves all suffer ( as stock) from a fuel pressure issue. Check the pressure at the pump-vp44- most likely the vp44 is not getting the fuel it needs to survive.
Then, (you will find it is low or non-existant) either buy a good aftermarket fuel pump, or build one for it.
Fass, airdog are two good examples.
Do not go to the intank set-up.
your system needs 15 psi max with at least 5-8 at full load.
you can search to your hearts content on this!!!!
Old Feb 19, 2009 | 01:22 PM
I took it to get diagnostics at Dodge today. They said injector pump and lift pump. What do you think? Thanks for your help.
Old Feb 20, 2009 | 02:01 PM
thumper549's Avatar
gives us the codes that were read on the scanner...It could be that, or a couple other things
Old Feb 23, 2009 | 10:54 AM
medicman202's Avatar
dealerships love to tell you its the injector pump then stick you with a $5000 bill. Read the Straight talk needed thread and you will see what I mean. It is must likely sucking air. I hope it helps
Old Feb 25, 2009 | 07:15 PM
took it to dixie diesel. no codes. new injector pump is being installed.
Old Feb 25, 2009 | 09:48 PM
thumper549's Avatar
wrong !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sory
Old Feb 25, 2009 | 10:06 PM
Say again thumper. What is?
Old Feb 25, 2009 | 10:43 PM
thumper549's Avatar
The VP will put up a code if it is dying,mostly dead, last legs.
In that year the L.P. will throw no code
Stalling and NO code is not a reason to sell you a VP...with out checking everything else 1st
Pontiac puller
Nov 9, 2003 09:22 PM
sparkys2500
Jul 3, 2003 07:19 AM
jlboren
Jun 2, 2003 08:38 PM
Guyver
Feb 25, 2003 01:26 PM
richard
Nov 23, 2002 03:03 AM
