stalling
Old Jan 20, 2009 | 11:40 AM
patpat paul's Avatar
stalling
i have a 98 12v and i keep having to pump the primer in order to keep it running replaced lines from tank to rail and from rail to motor no way to check fuel pressure but i am thinking lift pump any idea's
Old Jan 20, 2009 | 01:36 PM
1-2-3's Avatar
Just a plain ole guy
Just about answered your own question. Need to get a fuel pressure gauge on it. You can get simple test only gauges not intended for full time mounting at any auto parts store.
Old Jan 20, 2009 | 06:02 PM
yeh replaced it still has same problem??????????????
Old Jan 21, 2009 | 12:02 AM
mini14's Avatar
if fp is good then start looken for where u might be sucken air, loose fittings,clamps
Old Jan 21, 2009 | 07:17 AM
patdaly's Avatar
Check for air leak around your fuel heater and the top of the fuel tank module.
Had a 99 doing similar, steel hard lines to the tank module were rotted off at the tank.
Old Jan 21, 2009 | 08:40 AM
John Faughn's Avatar
It does not hurt to check / fix / replace fuel lines & hoses .
But check fuel pressure .
Old Jan 21, 2009 | 10:50 AM
thanx guys but dumb question how can i find a air leak i.e spay something or dump a fluid on it because it is in vacum and not positive presure from fuel tank to lift pump?????
Old Jan 22, 2009 | 10:10 AM
What I do is get an extra fuel tank cap , install a metal tire valve [ shrader valve ] , then put about 2-3lbs of air pressure into tank , then check every inch of line & hose , do forget the top of tank , its common for the lines coming out to rust .
Old Jan 22, 2009 | 05:50 PM
re stalling
ok replaced lines lift pump no air leaks and still does it i am baffled please any help i even pulled sending unit out of tank and looks and works good but still stalls then i have to pime and works for awhile
Old Jan 23, 2009 | 06:43 AM
I haven't seen any responses with test results , that's how things are fixed , testing tells what to replace .
Pontiac puller
Nov 9, 2003 09:22 PM
sparkys2500
Jul 3, 2003 07:19 AM
jlboren
Jun 2, 2003 08:38 PM
Guyver
Feb 25, 2003 01:26 PM
richard
Nov 23, 2002 03:03 AM
