spliting turbo - truck down !
Old Jul 4, 2003 | 12:45 PM
ramguy's Avatar
I need some info on replacing the turbo "18-16cm. Have a dodge truck manual but it's no help.
ramguy :'(
Old Jul 6, 2003 | 05:36 PM
firestorm's Avatar
Re:spliting turbo - truck down !
If you are pulling the turbo out as a unit, it is real simple.
1: Remove the air hoses (2) from the turbo.
2: Remove the lubrication lines (2), one on the top and one on the bottom.
3: Remove the exhaust pipe from the turbo.
4: Remove the turbo from the exhaust manifold.
5: Install in reverse order.
IMPORTANT: Fill the top oil hole in the turbo with clean motor oil.
Keep checking this oil level, and keep it full until the top oil line is hooked up.
When it is all installed, start the truck and let it idle for 5 minutes before putting it under a load to allow the lubrication of the turbo.
Old Jul 8, 2003 | 12:03 PM
ramguy's Avatar
I had the turbo off but the exaust housing didn't want to come off the bearing housing , thanks to Mr. torch ;D with some moderate heat and a little tapping with a hammer, Wala<br>off she came. Also pumped oil through bearings to keep them cool. Thanks for the help. ;D <br><br> ramguy
DAN POUCHER
Jun 14, 2008 06:52 PM
iker42
May 12, 2008 05:18 AM
DAN POUCHER
May 7, 2008 07:23 AM
CORed
Sep 20, 2006 08:25 PM
