Speedo maxed out
Old Oct 23, 2007 | 06:55 PM
rustybudweiser's Avatar
Speedo maxed out
okay just got done working on putting in a fuel pressure gauge. One thing is it's leaking bad and for the moment i had it on i had about 7 PSI at idle, got a ball vlave so it's shut off. Put the banjo bolt in and it was simple straight forward. no problems. Okay next issue, i cycled the LP 5 times or so and went to start, ran a couple seconds and died. so i tried cycling for a while more, still nothing. Cracked a couple lines and got fuel to them, then i got it to run and it died again however i did this for probably an hour and a 1/2, needless to say my batteries are getting old, didn't have enough juice to get started again. So i had to jump it because i don't have a battery charger at the moment, it's at my parents house over 4 hours away. Anyways, so i hooked it up and she cranked, well wouldn't start so i stepped on the go pedal since i've read some people on here doing that. She started and is going great now other than my gauge is leaking so i got to get it plumbed a little better. My main problem though is my speedo is maxed out, pegged clear past 120 and doesn't move, What's up? I'm scared I messed up something in the computer, please give me some answers quick? I'm going to do the key trick and see if it says anything?
Old Oct 23, 2007 | 07:01 PM
did the key trick and only code i got is the PC1693. Which i know is a companion code, so i guess i'll have to go to the dealer tomarrow or something unless someone knows something i don't. Please help me out.
Old Oct 23, 2007 | 07:40 PM
NVR mind. I did the gauge check reset by holding the trip reset button and turning the key and ended up fixing the problem. I figured out my own problem, i'm so happy when i can do that. lol.
Brendan
Mar 15, 2010 02:59 PM
dslpwr81
May 3, 2008 03:59 PM
tomgreentwin
May 24, 2006 08:50 AM
pwrtripls1
May 28, 2005 04:00 PM
