Sounds of the wheel
Old Jun 7, 2007 | 11:00 AM
Industriemontag's Avatar
Sounds of the wheel
Hello!
Has a problem with my Dodge and hope you can help me. Has squeaking of the front right wheel. Brake and other things I have already examined. It sounds, as if it comes from the warehouse in the stub axle. The sound was at the beginning only with curves trips, now, however, it always is there.
If developing wanted the stub axle, do not point, unfortunately, just like this should function. Can somebody explain to me just like this goes? I also have off the mother of the drive shaft and 2 nuts of the Joint at the top and below. And then I do not get on like this should go. (Vehicle has Allrad) Has somebody had perhaps already so a mistake?
Sorry, my English is not so good!
Gruß Marco
Old Jun 7, 2007 | 11:03 AM
donhov's Avatar
Before you can get much help need to know what you have. Please fill out your signature so that we can see what truck and options you have.
On to your question, just taking a wild guess have you checked the front universal (spicer) joints? That sounds like the first place I would start from from your description!!! A bad joint will squeel and clatter prior to ist's failing. Suggest you check or have tham checked first.
Old Jun 7, 2007 | 11:28 AM
I have controlled Yes joints. Sound is also with turn of the wheel by hand to hear. If it supposes comes from the warehouse.
Vehicle specifications:
Dodge RAM 4WD
Year of construction 2004
325PS 5,9l Diesel
TE-44
Nov 19, 2003 09:04 PM
redramnc
Aug 1, 2003 02:34 PM
BradN
May 19, 2003 11:14 AM
hammerjammer
May 7, 2003 04:03 PM
