Solonoid fuse problem
I had a problem with my solenoid fuse blowing, therefore truck would not start. A garage looked at it and their only resolution was possibly corrosion around the neutral safety switch. They started it 15 times with new fuse and all was well. Now 3 days later I am stranded again with the 20amp solenoid fuse blowing.
If anyone has an idea please post.
Thanks.
CJ
Thanks.
CJ
https://www.dieseltruckresource.com/...arter+contacts
here's your problem
here's your problem
Solonoid
Thanks so much for the help, The garage is saying that the starter is not drawing an excessive amount of amp draw but it kicks in when it gets the ole rap with a hammer, so it appears to be a starter. I cant figure out why its burning a fuse on the soloniod
