sliding fuel plate back?
Old Mar 26, 2006 | 09:22 PM
AMT's Avatar
AMT
Can anyone tell me if your fuel plate is slid forward,how far back is stock setting?And what happens if you slid it to far back.Will the engine not run at WOT,the gov.stopping it? This is on a 94 3500.Im just looking to put truck back to stock,knowing the tranny is stock and Noooo gauges! THANKS (Ill get some pic of truck as soon as it closer to done)
Old Mar 26, 2006 | 09:28 PM
TxDiesel007's Avatar
stock position is dead center
If you set the plate farther back, all you are doing is actually limiting fuel to the pump. I have ran the plate back and have not had issues with the governer stopping it, BUt the truck did run slower and i had no smoke.
Rick
Old Mar 27, 2006 | 12:53 AM
P.O.R.'s Avatar
don't forget to check and or adjust gov. arm after moving the plate,here is a link.
http://www.piersdiesel.com/TechLeverAdj.htm
Old Mar 27, 2006 | 09:42 AM
infidel's Avatar
Not true, the position is different on every engine, they are individually adjusted. That's why it's always a good idea to mark the position of the stock plate before removing it. If you have the the stock plate sometimes you can find were it was originally installed by the screw marks on it.
Old Mar 27, 2006 | 12:36 PM
jaconst's Avatar
when they time the pump is that just sliding the torque plate? they said when I took it in after I bought it that they set it at something like 16.5* or 17* degrees I can't remember
Old Mar 27, 2006 | 02:56 PM
plow's Avatar
When I first did mine it was already full forward. It came from factory like this. I have worked on several that were completly stock and have never been touched and have only seen one other that was full forward from factory. Infidel ,why does it vary so much?
Old Mar 27, 2006 | 07:25 PM
infidel's Avatar
Each engine is adjusted on a test stand before it leaves the factory to meet smog laws. My guess is the range of adjustment the plate has is designed for smog, not for more power. I have also come across a couple of stock plates that were full forward and the housing covers for sure had never been removed.
Same with the AFC housing and starwheel, they are are in all different positions as they come from the factory.
Can't vouch for it but have read that each engine is run for at least five hours, fine tuned, the oil and coolant drained before it leaves the Cummins factory.
jaconst, timing and plate position are two different adjustments. The plate limits the amount of fuel delivered according to rpm and load. The effect of moving the plate fore or aft can be noticed in movements of a hundredth of an inch, sliding the plate full forward is actually a pretty drastic adjustment. But it works...
The timing determines at which position of piston stroke that fuel is injected and is adjusted by moving a gear on the front of the engine that determines the relationship in position between the injection pump and the cam.
Old Mar 27, 2006 | 08:38 PM
jaconst's Avatar
thanks infedel, I'll throw up a thread with a couple questions on the plate I should get. also what ever happened to wierd ebay auctions in the other threads I miss those, sorry for hijacking the thread
bairwin
Aug 24, 2008 08:00 AM
Diesel97
15
Jun 30, 2007 08:34 AM
Tim9712v
18
Feb 13, 2007 10:35 PM
JTaylor
Nov 27, 2006 05:29 PM
yrusoslow2
Sep 11, 2003 07:46 AM
