Slave cylinder installation
Old May 25, 2010 | 05:49 PM
KWLWEW's Avatar
I had to replace my clutch master and slave cylinder, the problem is the new one is two pieces and is pre-bled. The slave cylinder has a small white cap over the end of the piston that is held down by plastic tabs. Do I take those tabs loose and release the piston before I plug it into the hose that connects it to the master cylinder or do I plug it in first and then release those tabs? Or does it matter?
Old May 25, 2010 | 07:11 PM
Onemoparnut's Avatar
Please fill out your signature so we know what kind of truck we are helping you work on
Old May 26, 2010 | 07:52 AM
FMB's Avatar
FMB
Originally Posted by KWLWEW
Do I take those tabs loose ... or do I plug it in first and then release those tabs? Or does it matter?
When I replaced my M/S I left the tabs in place thinking that if the clutch pedal pressure doesn't snap the tabs, I can take it out and snap them. I didn't have to break the tabs, no issues, went in fine and worked well for many thousand miles.
I replaced the clutch this month so I had the opportunity to look at those tabs and install the slave without the tabs. I didn't see any issues. Re-installation went well, wasn't that much of a push onto the studs to get the nuts started.
Back to morning brew...
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Heeler00
Feb 18, 2004 01:52 PM
Strange
Jan 24, 2004 06:45 PM
