slave cylinder
Old Jan 2, 2005 | 06:52 PM
lbushue's Avatar
slave cylinder
Can anyone tell me how much distance the slave cylinder moves? I think that is the problem, not sure if it is working right.
Old Jan 2, 2005 | 07:03 PM
thumper 549's Avatar
Not sure how much it moves,,but if the clutch is draging, trany clashing your on to the common problem
Old Jan 2, 2005 | 10:32 PM
Hemi Cat's Avatar
Another common problem for hard shifting or grinding is the pilot bearing going dry and eating the input shaft.
Old Jan 3, 2005 | 07:53 AM
Rammer64's Avatar
Signature
lbushue
You should fill out your signature to give everyone a better idea of what you have.
It helps everyone be alot more specific to YOUR vehicle.
Old Jan 3, 2005 | 08:16 AM
lbushue's Avatar
Thanks for the input.
Old Jan 4, 2005 | 05:27 PM
1st gen Hobie's Avatar
Was I supposed to lube the piolot bushing when installing it?
Old Jan 4, 2005 | 11:29 PM
scuzman00's Avatar
I just played the whole scenario of bad hydraulic system stuff. If you have any air small (and I mean small) leaks in the system, you can do all kinds of second guessing to figure out problems. I bought all new primary and slave cylinders and still had aproblem. I had supplier of master cylinder get in touch with factory and give me a new lesson on "bleeding master and slave cylinders" which I followed to a T still fail. The problem was still air in the system untill I found out that the aftermarket slave cylinder was approximately 1/8" short of a full stroke from completing the clutch cycle........ Guess you live and learn and shorten your wallet padding in the course......
Good Luck,
Gary
Old Jan 5, 2005 | 12:17 AM
Hemi Cat's Avatar
Yes, use a good hi temp grease and try to pack it in the bearing. Don't over do it because the excess grease will sling out on the disc and cause a grabby clutch for a while.
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Heeler00
Feb 18, 2004 01:52 PM
Strange
Jan 24, 2004 06:45 PM
