Scraping sound
Old Nov 10, 2005 | 07:36 PM
fishntexan's Avatar
Scraping sound
My ram starting making a scraping noise this afternoon while driving down highway. I thot a tailpipe or something was draggin. Nothing is visible under the truck or in the motor. Starts at about 40mph and quits when u slow down. No effect if you put in neutral at 40+. sounds like it is coming from the front, but no evidence of heating, low oil pressure, or alt probs. Maybe some diesel smell, but not sure at there was lots of traffic. Nothing in wheel caps. Any ideas?
2003 quad 3/4 ton 4x4 24v diesel
Old Nov 10, 2005 | 07:50 PM
phox_mulder's Avatar
Did it sound like gravel in a steel hubcap?
When mine did that it was the front driveshaft, imploded CV joint.
Make sure you are going straight and put it in 4 wheel drive and see if the noise gets much much worse, if so, there's your culprit.
phox
Old Nov 11, 2005 | 07:41 AM
P.O.R.'s Avatar
check the front wheel bearings
Old Nov 12, 2005 | 07:15 PM
mr T's Avatar
check the wheelbearings/hub assembly for a small rock stuck there....i can't imagine ur hub needing a replacment cause its sucha new truck...
i had to replace mine on the drivers side....after last winter...it just seized up ...have to get the new hub...but it served 10 years won't complain
dieselcarpenter
Jun 11, 2011 06:03 PM
rbox
Jan 18, 2009 01:34 AM
Taxidermyman
Mar 15, 2008 01:06 AM
PaulDaisy
26
Dec 22, 2006 12:38 AM
