Scraping sound on cold start
Old Jan 16, 2009 | 02:31 AM
rbox's Avatar
I am getting a scraping/squeaking sound from the engine when the engine is cold. It usually goes away once the engine is warmed up. Today it was 21 deg and it lasted for a while. It has turned from a squeaking to more of a scraping sound recently. Does this engine have a idler pulley that goes bad? Is there another pulley that commonly goes out?
Old Jan 16, 2009 | 01:54 PM
DTE's Avatar
DTE
had a funny scraping noise that eventually got worse and then became an idler pulley failure
Old Jan 16, 2009 | 07:26 PM
JRD's Avatar
JRD
Power steering pump? Does it sound like this on start up?
http://www.youtube.com/watch?v=1DByvpmnwgE
Got the video clip from this thread.
https://www.dieseltruckresource.com/...d.php?t=229723
Hope this helps ya.
Old Jan 16, 2009 | 11:26 PM
rbox's Avatar
Hope this helps ya.
not near that loud, you really can't hear it unless you are in front of the truck.
Old Jan 17, 2009 | 04:24 PM
cowbizzoy's Avatar
mine makes a noise similar to what you describe when its cold, if I don't plug it in....
I'd try pluggin her in, see if that makes a difference. I also find it sounds a lot better since i switched to synthetic oil (amsoil in particular)
Old Jan 17, 2009 | 11:02 PM
Thundercraft's Avatar
My guess would be idler too. Try shooting some WD40 or something like that at it (not the surface belt area, but the center bearing area). If it shuts it up, you know where your problem is. This "fix" only lasts a day or so.... it is just helping you narrow down the problem.
Forgot what it cost me at the auto parts store - but the part they sold me was actually made in Canada and didn't come on the slow boat from somewhere.
Old Jan 18, 2009 | 01:34 AM
rbox's Avatar
Thanks for the help. I will try the WD40.
dieselcarpenter
Jun 11, 2011 06:03 PM
Taxidermyman
Mar 15, 2008 01:06 AM
PaulDaisy
26
Dec 22, 2006 12:38 AM
fishntexan
Nov 12, 2005 07:15 PM
