Rusty brake line, where to get on Sunday?
Old May 6, 2007 | 09:12 AM
speedster1858's Avatar
Hi,
Rusty brake lines. It's Sunday, can I buy a stock line to replace the steel line that goes from the rear axle and past the fuel tank? How long is it? Where is the forward end?
Thanks,
Mike
Old May 6, 2007 | 09:18 AM
schoust's Avatar
Been there myself,this happened to me a couple of weeks back on a Sunday my lines ended up rotting out on the inside of the frame between the fuel tank and frame rail. What I would do is just go to one of the big box auto parts stores and buy the correct size line and some fittings make sure you get a couple of unions in case you can't get there with one piece and have at it....
Old May 6, 2007 | 09:25 AM
Shoust,
Thanks for the reply. Do you know the correct size line for my 1996 2500?
Mike
Old May 6, 2007 | 09:45 AM
Should be 1/8", but it might be 1/4". Make sure you get line with SAE fittings, not metric. Get longer sections than you think you need and put a "Z" bend in it to shorten it up (be careful not to kink it). That'll get you through until you can get a new line or a good double flaring tool to make your own.
Old May 6, 2007 | 01:58 PM
Hi,
Rusty brake line past fuel tank fixed. Two 60" and one 30" 3/16" brake lines plus two connectors was the perfect length to run new brake lines from the junction block on the frame, driver's side, near axle to the junction block behind the driver's side front wheel. Thanks to Schoust and Wannadiesel!
Mike
Old May 6, 2007 | 03:40 PM
schoust's Avatar
Piece of cake! Have you done your fuel lines yet? If not be prepared because they are next...........
snowmanx
May 23, 2010 09:18 PM
asnowsquall
Mar 15, 2009 06:59 PM
pappyman
May 30, 2004 03:06 AM
Cowhand
Apr 19, 2004 07:02 PM
