Rough Idle
Old Oct 17, 2005 | 05:45 PM
capt.Ron's Avatar
I think I can... I think...
I've been having some low and rough idle issues lately so I added a little of the meaner cleaner to about 1/3 tank of fuel and It seemed to run smoother after that. I have since filled up with B20 and added the meaner cleaner as well. Didn't really drive it very far after that so it's hard to tell just yet.
I've heard dumping 1 qt of trans fluid into a full tank will also lube and clean the pump and injectors.....Anyone try, recommend or discourage this?
Old Oct 17, 2005 | 06:49 PM
Smokee's Avatar
Not a good recommendation. Do not add tranny fluid.
Old Oct 17, 2005 | 07:12 PM
Dr. Evil's Avatar
Strongly DISCOURAGE !!
The additives in the ATF will kill your injector pump in no time. Have you priced an injector pump?
Use a proper additive.
Old Oct 17, 2005 | 08:46 PM
MCummings's Avatar
Originally Posted by Haulin_in_Dixie
I tried this in another thread before but don't believe that I got an answer that worked for me. The truck runs great, good power, good mileage. Sparadically it will idle rough. Sometimes it is totally smooth, sometimes a little sparadic miss, sometimes real rough. Air and fuel filters are clean, could be the winter fuel at some truck stops but don't think so. Cold or warm does not seem to matter. <br><br>I see some real good knowledge about sensors here, any ideas?
HID,
I have a customer with the same problem. Starts fine, has normal power, gets good mileage, but occasionally, especially when hot, it gets a really random miss. no sync, or rythym to it. It will miss 3-4 times in a seconds, then will idle smooth for another scond, then rough again.
I can't figure it out.
New filters, good fuel pressure, 8 month old injection pump, OE injectors w/110k.
Any idea's?
Thanks,
Merrick
Old Oct 17, 2005 | 09:42 PM
capt.Ron's Avatar
Hmmmm, I guess ATF is out of the question then
Old Oct 17, 2005 | 09:52 PM
Dr. Evil's Avatar
Uh, yeah...it would be ok to use ATF if you dont mind buying a new IP to the tune of $1100
Old Oct 17, 2005 | 11:13 PM
capt.Ron's Avatar
Doesn't sound like a good alternative to me.
Old Oct 23, 2005 | 10:04 PM
capt.Ron's Avatar
Well after running 1/2 tank of B-20 with the Howes meaner power Kleener my truck is running extremely well! I had been getting a shudder anytime I stopped at a light. At first I thought my idle was set too low but after the additive and the bio it idles higher when in park and when in gear. Also I've been getting really bad fuel mileage but I pulled my 16' utiity trailer for 270 miles at an 80MPH speed average and only burned 1/2 tank. My mileage had been running around 14 mph lately but it looks like it will be much better on this tank. I'll post again when I fill up and do the math.
banks twinram
May 18, 2010 08:10 PM
turbov6joe
Sep 25, 2003 10:57 AM
TheMoose
Sep 20, 2003 07:44 PM
Mexstan
Mar 31, 2003 02:37 PM
