Rough idle
Rough idle
Put quad race #2 on yesterday everything fine.Washed udder hood today with only garden hose started truck to let engine run to dry every thing out.Washed truck went to move truck it is dieseling real bad and running rough.
Must've gotten a few connections wet. You'll need some contact cleaner and di-electric grease. P0192-Fuel Rail Pressure Sensor, unplug and spray it down w/ a little cleaner, smear some grease on the plug and hook up. Should fix the problem.
Every thing was put togeather with dielectric grease.Re started many times ran fine shut off hard to start again.It went as far as to start and die.Un hooked all the quad wireing starts hard and diesels real bad.
banks twinram
May 18, 2010 08:10 PM
turbov6joe
Sep 25, 2003 10:57 AM
