roll over but wont crank
got the truck cranking went the next morning to go to work but the same thing happened roll over but will not bust off . i got a buddy with a scan tool pulled code 1689(no communication between ecm and injection pump)today i separated the wire harnesses between the ip and the ecm sprayed with contact cleaneradn reassembled. the truck started 4 times on the 5th try the **** thing just rolled over again. i dont know if the ecm is taking a **** or if a have another fault? how in world would u check the ecm?any help would b greatly appreiciated.
Welcome to the site JW3,
Click on User CP above and to the left of your post. Then click on Edit Signature and fill it in with your truck description. This will help the folks help you with diagnosing your problems. Hopefully someone can help you out. We have some very knowledgeable members here!
Originally Posted by J BODY
Dealer has a test tool. Unplug VP44, plug in test tool, see if truck starts....That would be an easy way to tell which direction to go.
u say ur in texas give me a shout or private message me im having hell outa a 2000 3500 4x4 5 speed with a no start condition. the **** thing is getting fuel but what else could it be
upchurch30
Sep 16, 2008 12:06 AM
Dufrain
Mar 11, 2007 03:04 PM
Tank_66
18
Dec 31, 2006 02:15 PM
