this **** truck
Old Dec 26, 2005 | 01:05 PM
JW3's Avatar
JW3
this EDIT truck
where can a man find the dodge trouble shootin flow chart on a no start condition? the truck is a 2000 with non mechanical mods. appreiciate any input yall can give!
Old Dec 26, 2005 | 01:17 PM
MnTom's Avatar
What kind of symptoms do you have? Does it turn over like normal without firing? Does it fire some but not enough to get going? Do you have any codes? All they need is air and fuel to run. If it does not fire chances are there is no fuel to the injectors. Start by checking fuel pressure. Then make sure you are getting fuel to the VP. After that try cracking an injector line and see if you are getting fuel. The fuel should spray out of the cracked injector line not dribble out. Give this stuff a try and let us know how you make out.
Tom
BTW, Fill out your signature so we can help you better.
Old Dec 26, 2005 | 02:23 PM
John Faughn's Avatar
I'll 2nd that , fill out your sig. with truck info . a couple sites that , I know at least one of then had it .http://www.genosgarage.com/
Geno's Garage: Your Number One Resource For Dodge, Dodge Diesel, Cummins, Ford, Ford Powerstroke, GMC, Chevy, GMC/Chevy Duramax Gauges, Filters, and Accessorieshttp://
www.dodgeram.org/tech/repair/index.html
DIY Ram repair noteshttp://
www.dodgedieseldatabase.com/
Dodge Diesel Database
Old Dec 26, 2005 | 02:24 PM
crobtex's Avatar
Where are you in Texas? Help may be closer then the know.
Fill in your sig info and let's see what we can figure out.
Old Dec 26, 2005 | 05:30 PM
JW3's Avatar
JW3
my bad guys
im in corsicana,tx. my truck is a 2000 3500 4x4 quad cab with a 5 speed. the truck will not crank unless u give it a shot of either(i know bad idea) i have got 14lbs. to the injector pump and i am getting good flow out of an injector when i craked one i would be thankful for any help
Old Dec 26, 2005 | 05:50 PM
crobtex's Avatar
I hate to be the bearer of bad news, but I saw one do the EXACT same thing as yours a few weeks ago, and it was the injector pump. Ether to start, and then it would run, but not idle very well. I'm not sure, but the fuel your getting to the injector lines may be what's being pushed thru by the fuel pump.
Do you have any codes? You may have to find a high dollar code reader, but you'll find you probably have a 216, which is the injector pump failure.
DON'T take it back to a Dodge dealer unless it's still in warranty! Find a good place that understands the VP 44 and take it there. If there is not one in Corsicana, you can probably find one in Waco.
I hope I'm wrong.
Old Dec 26, 2005 | 09:32 PM
MCummings's Avatar
A 24v has to have good batteries to start. If the voltage falls below the "safe" margin when crankin, the batteries are on the verge of being to low to fire the truck.
If the truck starts with either, or is hard to start when hot, then it's 99% the injection pump.
My bet is on the abtteries, being that cold weather is just coming around...
Merrick
Old Dec 26, 2005 | 09:58 PM
high country's Avatar
do not buy a vp untill you are sure it is not a small air leak in a fuel line
Old Dec 26, 2005 | 10:13 PM
J BODY's Avatar
Crack three of them open. 1,3,4 are accessable.
Old Dec 27, 2005 | 01:40 AM
AggiePhil's Avatar
See if it's pulling any codes. Turn the key on, then off; on then off; on and leave it. See what displays in the odometer and get back to us.
Old Dec 27, 2005 | 10:03 PM
JW3's Avatar
JW3
hey guys no codes through reader or odometer, cracked the injectors how much is enough?? it seemed to be getting enough fuel but i dont know
. appreicated the help.the truck has good batteries.idle on this truck is just like it was new
Old Dec 27, 2005 | 10:09 PM
phox_mulder's Avatar
Should be coming out high pressure.
Just dribbling out tells you your injection pump is gone, and the lift pump is just pushing fuel through it.
phox
Old Dec 27, 2005 | 11:06 PM
Mt Ram's Avatar
Just a dumb question, but does it have DIESEL in it (the tank) or did it get filled with something else by mistake? Also try using a booster battery on it, the VP44 is a rotary type of injection pump and they will not pump if the cranking speed is to low. A 5 rpm drop in cranking speed can make the difference if the batteries are borderline. Hope this helps.
Old Dec 27, 2005 | 11:34 PM
Geico266's Avatar
Get a fuel pressure guage to avoid this in the future.
brandon507
23
Jul 16, 2004 07:32 PM
natstayl
Jun 18, 2004 01:39 AM
sandpuller2004
14
Jun 4, 2004 12:14 PM
Herve
23
Mar 7, 2004 10:24 AM
